Home » Modeling » GMF (Graphical Modeling Framework) » How to enable Format Line Type, Line Width for connections
How to enable Format Line Type, Line Width for connections [message #207818] Fri, 03 October 2008 11:44 Go to next message
Originally posted by: mklinchin.yahoo.com
In my diagram when I right click on connection line (polyline connection
in graphical model) and select Format / Line Width all possible selections
are disabled. Same thing happens when I select Line Type or Arrow Type.
However Line Style as well as Line Color options are enabled.
I checked LineWidthAction.calculateEnabled() and found that
style.getLineWidth() there is -1. I also checked
LineTypeAction.calculateEnabled() and found that style there is null. But
I have line width in my graphical model set to 1.
Thank you for helping me
Igor
Re: How to enable Format Line Type, Line Width for connections [message #207899 is a reply to message #207818] Mon, 06 October 2008 17:42 Go to previous messageGo to next message
Hi Igor,
1) in your XXXXConnectionViewFactory, you already likely have the
ConnectorStyle installed, set the default line width and add arrow and line
type styles.
Add:
ConnectorStyle style = (ConnectorStyle) styles.get(0);
if (style != null) {
style.setLineWidth(1);
styles.add(NotationFactory.eINSTANCE.createArrowStyle());
styles.add(NotationFactory.eINSTANCE.createLineTypeStyle());
2) in your XXXXConnectionEditPart, I will assume you want to place an arrow
on both source and target. You will need to remove the local
ConnectionFigure and replace with
* @generated NOT
protected Connection createConnectionFigure() {
return new PolylineConnectionEx();
* @generated NOT
public PolylineConnectionEx getPrimaryShape() {
return (PolylineConnectionEx) getFigure();
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#handleNotificationEvent(org.eclipse.emf.common.notif y.Notification)
protected void handleNotificationEvent(Notification notification) {
Object feature = notification.getFeature();
if (NotationPackage.Literals.LINE_STYLE__LINE_WIDTH.equals(feat ure)) {
refreshLineWidth();
refreshArrowSource();
refreshArrowTarget();
} else if (NotationPackage.Literals.LINE_TYPE_STYLE__LINE_TYPE
.equals(feature)) {
refreshLineType();
} else if (NotationPackage.Literals.ARROW_STYLE__ARROW_SOURCE
.equals(feature)) {
} else if (NotationPackage.Literals.ARROW_STYLE__ARROW_TARGET
.equals(feature)) {
} else {
super.handleNotificationEvent(notification);
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#refreshVisuals()
protected void refreshVisuals() {
super.refreshVisuals();
refreshLineWidth();
refreshLineType();
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setLineWidth(int)
protected void setLineWidth(int width) {
getPrimaryShape().setLineWidth(getMapMode().DPtoLP(width));
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setLineType(int)
protected void setLineType(int lineType) {
getPrimaryShape().setLineStyle(lineType);
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setArrowSource(org.eclipse.draw2d.RotatableDecoration)
protected void setArrowSource(RotatableDecoration arrowDecoration) {
getPrimaryShape().setSourceDecoration(arrowDecoration);
* @see
org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setArrowTarget(org.eclipse.draw2d.RotatableDecoration)
protected void setArrowTarget(RotatableDecoration arrowDecoration) {
getPrimaryShape().setTargetDecoration(arrowDecoration);
Hope this helps.
Cheers...
Anthony
"Igor Klinchin" <mklinchin@yahoo.com> wrote in message
news:pan.2008.10.03.15.44.21.464431@yahoo.com...
> Hello,
> Igor
Re: How to enable Format Line Type, Line Width for connections [message #207906 is a reply to message #207899] Mon, 06 October 2008 18:41 Go to previous messageGo to next message
Hi Anthony,
Thank you very much for your answer. I found the classes you refer to. My
XXXXConnectionViewFactory.createStyles contains the code you mention. It
looks like this:
List styles = new ArrayList();
styles.add(NotationFactory.eINSTANCE.createConnectorStyle()) ;
styles.add(NotationFactory.eINSTANCE.createFontStyle());
But this code is never called. I set up a breakpoint there and it is never
reached. Actually, it seems to be a reason why these styles are not
defined. How can I make this code run?
Thank you agian,
Igor
On Mon, 06 Oct 2008 17:42:20 -0400, Anthony Hunter wrote:
> Hi Igor,
> type styles.
> Add:
> * @generated NOT
> * @generated NOT
> * @see
> refreshLineWidth();
> .equals(feature)) {
> refreshLineType();
> .equals(feature)) {
> .equals(feature)) {
> } else {
> * @see
> refreshLineWidth();
> refreshLineType();
> * @see
> * @see
> * @see
> * @see
> Hope this helps.
> Cheers...
> Anthony
>> Hello,
>> Igor
Re: How to enable Format Line Type, Line Width for connections [message #207954 is a reply to message #207906] Tue, 07 October 2008 10:59 Go to previous message
Hi Anthony,
I regenerated Diagram and Edit and everything works now. Thank you
very much for advice.
Igor
On Mon, 06 Oct 2008 18:41:30 -0400, Igor Klinchin wrote:
> Hi Anthony,
> looks like this:
> Thank you agian,
> Igor
>> Hi Igor,
>> type styles.
>> Add:
>> * @generated NOT
>> * @generated NOT
>> * @see
>> refreshLineWidth();
>> .equals(feature)) {
>> refreshLineType();
>> .equals(feature)) {
>> .equals(feature)) {
>> } else {
>> * @see
>> refreshLineWidth();
>> refreshLineType();
>> * @see
>> * @see
>> * @see
>> * @see
>> Hope this helps.
>> Cheers...
>> Anthony
>>> Hello,
>>> Igor
Previous Topic:CheckboxTreeViewer with Checkboxes only on top level?
Next Topic:Context Menu Action validate
Current Time: Sat Jul 26 08:55:56 EDT 2025
Powered by FUDForum. Page generated in 0.08533 seconds
