How to enable Format Line Type, Line Width for connections [message #207818] |
Fri, 03 October 2008 11:44  |
Originally posted by: mklinchin.yahoo.com
In my diagram when I right click on connection line (polyline connection
in graphical model) and select Format / Line Width all possible selections
are disabled. Same thing happens when I select Line Type or Arrow Type.
However Line Style as well as Line Color options are enabled.
I checked LineWidthAction.calculateEnabled() and found that
style.getLineWidth() there is -1. I also checked
LineTypeAction.calculateEnabled() and found that style there is null. But
I have line width in my graphical model set to 1.
Thank you for helping me
Igor
Re: How to enable Format Line Type, Line Width for connections [message #207906 is a reply to message #207899] |
Mon, 06 October 2008 18:41   |
Hi Anthony,
Thank you very much for your answer. I found the classes you refer to. My
XXXXConnectionViewFactory.createStyles contains the code you mention. It
looks like this:
List styles = new ArrayList();
styles.add(NotationFactory.eINSTANCE.createConnectorStyle()) ;
styles.add(NotationFactory.eINSTANCE.createFontStyle());
But this code is never called. I set up a breakpoint there and it is never
reached. Actually, it seems to be a reason why these styles are not
defined. How can I make this code run?
Thank you agian,
Igor
On Mon, 06 Oct 2008 17:42:20 -0400, Anthony Hunter wrote:
> Hi Igor,
> 1) in your XXXXConnectionViewFactory, you already likely have the
> ConnectorStyle installed, set the default line width and add arrow and line
> type styles.
> Add:
> ConnectorStyle style = (ConnectorStyle) styles.get(0);
> if (style != null) {
> style.setLineWidth(1);
> styles.add(NotationFactory.eINSTANCE.createArrowStyle());
> styles.add(NotationFactory.eINSTANCE.createLineTypeStyle());
> 2) in your XXXXConnectionEditPart, I will assume you want to place an arrow
> on both source and target. You will need to remove the local
> ConnectionFigure and replace with
> * @generated NOT
> protected Connection createConnectionFigure() {
> return new PolylineConnectionEx();
> * @generated NOT
> public PolylineConnectionEx getPrimaryShape() {
> return (PolylineConnectionEx) getFigure();
> * @see
> org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionNodeE ditPart#handleNotificationEvent(org.eclipse.emf.common.notif y.Notification)
> protected void handleNotificationEvent(Notification notification) {
> Object feature = notification.getFeature();
> if (NotationPackage.Literals.LINE_STYLE__LINE_WIDTH.equals(feat ure)) {
> refreshLineWidth();
> refreshArrowSource();
> refreshArrowTarget();
> } else if (NotationPackage.Literals.LINE_TYPE_STYLE__LINE_TYPE
> .equals(feature)) {
> refreshLineType();
> } else if (NotationPackage.Literals.ARROW_STYLE__ARROW_SOURCE
> .equals(feature)) {
> } else if (NotationPackage.Literals.ARROW_STYLE__ARROW_TARGET
> .equals(feature)) {
> } else {
> super.handleNotificationEvent(notification);
> * @see
> org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#refreshVisuals()
> protected void refreshVisuals() {
> super.refreshVisuals();
> refreshLineWidth();
> refreshLineType();
> * @see
> org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setLineWidth(int)
> protected void setLineWidth(int width) {
> getPrimaryShape().setLineWidth(getMapMode().DPtoLP(width));
> * @see
> org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setLineType(int)
> protected void setLineType(int lineType) {
> getPrimaryShape().setLineStyle(lineType);
> * @see
> org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setArrowSource(org.eclipse.draw2d.RotatableDecoration)
> protected void setArrowSource(RotatableDecoration arrowDecoration) {
> getPrimaryShape().setSourceDecoration(arrowDecoration);
> * @see
> org.eclipse.gmf.runtime.diagram.ui.editparts.ConnectionEditP art#setArrowTarget(org.eclipse.draw2d.RotatableDecoration)
> protected void setArrowTarget(RotatableDecoration arrowDecoration) {
> getPrimaryShape().setTargetDecoration(arrowDecoration);
> Hope this helps.
> Cheers...
> Anthony
> "Igor Klinchin" <mklinchin@yahoo.com> wrote in message
> news:pan.2008.10.03.15.44.21.464431@yahoo.com...
>> Hello,
>> Igor
Re: How to enable Format Line Type, Line Width for connections [message #207954 is a reply to message #207906] |
Tue, 07 October 2008 10:59  |
Hi Anthony,
I regenerated Diagram and Edit and everything works now. Thank you
very much for advice.
Igor
On Mon, 06 Oct 2008 18:41:30 -0400, Igor Klinchin wrote:
> Hi Anthony,
> looks like this:
> Thank you agian,
> Igor
>> Hi Igor,
>> type styles.
>> Add:
>> * @generated NOT
>> * @generated NOT
>> * @see
>> refreshLineWidth();
>> .equals(feature)) {
>> refreshLineType();
>> .equals(feature)) {
>> .equals(feature)) {
>> } else {
>> * @see
>> refreshLineWidth();
>> refreshLineType();
>> * @see
>> * @see
>> * @see
>> * @see
>> Hope this helps.
>> Cheers...
>> Anthony
>>> Hello,
>>> Igor
FUDForum. Page generated in 0.45460 seconds
