Home » Newcomers » Newcomers » JDK Docs
JDK Docs [message #205942] Wed, 18 April 2007 22:45 Go to next message
Originally posted by: pat.parkplacesolutions.com
How do I configure eclipse to use JDK docs or how do I get to it from
Eclipse
Re: JDK Docs [message #206001 is a reply to message #205942] Thu, 19 April 2007 02:31 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
> Eclipse
If you are running Eclipse with a JDK (as opposed to a JRE) it should
locate the docs for you as long as they are installed with the JDK.
Otherwise, you can define an alternate JRE that is the JDK (under
Preferences >Java > Installed JREs. Again, if it is a JDK it will find
the Javadocs for you. You can always set their location manually; see
this screencast (it shows setting the source location, but Javadoc
location is right next to that).
Hope this helps,
Eric
Re: JDK Docs [message #206492 is a reply to message #206001] Fri, 20 April 2007 19:21 Go to previous messageGo to next message
Eric Rizzo wrote:
>> Eclipse
Oops, I forgot the link to the screencast. Here it is:
http://www.rizzoweb.com/Eclipse/JDKSourceAttachment.html
Eric
Re: JDK Docs [message #206910 is a reply to message #206492] Mon, 23 April 2007 10:40 Go to previous messageGo to next message
Originally posted by: landolini.yahoo.it
I wish to see the docs in the browser...but also with
Shift + F2 the browser doesn't start...and I don't see
nothing.
I've the libraries as you show in your page.
Many thanks.Regards
Re: JDK Docs [message #206976 is a reply to message #206910] Mon, 23 April 2007 16:22 Go to previous messageGo to next message
Though I set the docs path to //docs/api , Eclipse change it
to this wrong way !!! >>>
http://immagini.p2pforum.it/show.php/141373_screenshotEclips e4.png.html
Re: JDK Docs [message #207315 is a reply to message #206976] Tue, 24 April 2007 21:09 Go to previous messageGo to next message
Remember that you can have any number of JREs configured in Eclipse. IF
you set the Javadoc location for one of them make sure that is the JRE
that is being used when you launch your program, or set the proper
Javadoc location for all the JREs listed in Preferences > Java >
Installed JREs.
Hope this helps,
Eric
Re: JDK Docs [message #207395 is a reply to message #207315] Wed, 25 April 2007 06:06 Go to previous messageGo to next message
> Installed JREs.
> Hope this helps,
> Eric
I've done this procedure . And repeted many times !
window > preferences > Java > installed JREs
jdk1.5.0_07
/home/myname/jdk1.5.0_07
Edit
Select > /home/myname/jdk1.5.0_07/jre/lib/rt.jar
add Javadoc location > home/myname/jdk-1_5_0-doc/docs/api
See >>>
http://immagini.p2pforum.it/out.php/i142336_EclipseEditJRE1. png
THEN Shift + F2 on my source Applet, JApplet keyword
and I get >
THIS is right ! because the javadoc location has changed ! >>>
http://immagini.p2pforum.it/out.php/i142337_EclipseEditJRE2. png
....in fact the JApplet.html right location is >>>
/home/lando/jdk-1_5_0-doc/docs/api/javax/swing/JApplet.html
Without the /java/ folder that Eclipse has appended after /api/ .
And this is the problem.
Thanks a lot for your help .
Re: JDK Docs [message #207595 is a reply to message #207395] Wed, 25 April 2007 14:17 Go to previous messageGo to next message
> jdk1.5.0_07
> Edit
> See >>>
> and I get >
Please file a bug report with the exact steps to reproduce the problem:
http://bugs.eclipse.org/bugs
Eric
Re: JDK Docs [message #207767 is a reply to message #207595] Thu, 26 April 2007 11:14 Go to previous message
>> jdk1.5.0_07
>> Edit
>> See >>>
>> and I get >
> Eric
I've done , the bug is 184115 .
Regards , Lando.
Previous Topic:Plugin .jar?
Next Topic:Autopopulate VM arguments in run configurations
Current Time: Fri Jul 18 11:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.11030 seconds
