| Install Problems [message #20769] |
Thu, 26 February 2004 10:30  |
Only one comment about this editor WOW
Problem:
delete old version of eclipse
restart
install in this order
eclipse-SDK-I20040225-win32.zip
emf_2.0.0_20040127_1738SL.zip
GEF-runtime-3.0M7.zip
VE-SDK-N20040225.zip
start eclipse (with no arguments)
new/project/java/java project
new/visual class
The finish button is enabled but has no effect
System XP Home edition
I have use the previous version with no problems
and have tried this sequence a number of times
Andre
also if I start this version with an existing project
C:\eclipse\eclipse.exe -data c:\e_data -vm C:\j2sdk1.4.1_01\jre\bin
\javaw.exe
and open an existing class with the visual editor it seems to prepare the
visual bot does not display the result. The component window is also empty
in this case.
The actual application works properly.
| Re: Install Problems [message #21362 is a reply to message #20876] |
Fri, 27 February 2004 10:25  |
Rich Kulp <richkulp@NO.SPAM.us.ibm.com> wrote in news:c1lost$6kn$2
@eclipse.org:
> ALSO, you will need to pick up todays version of Eclipse. There was a
> problem with the Eclipse I20040225 driver that caused EMF to not work.
> this was fixed with the Eclipse I20040226 driver.
The nightly build for Eclipse is still pointing to 225 so other may have
the same problem. Downloading 227 jope it will be ok. Will post if it is
not.
| Re: Install Problems [message #582553 is a reply to message #20769] |
Thu, 26 February 2004 16:12  |
Andre Arpin <arpin@kingston.net> wrote in
news:Xns949B6B6C495C7arpinkingstonnet@204.138.98.10:
> Problem:
> restart
> new/visual class
> Andre
> \javaw.exe
> the visual bot does not display the result. The component window is
> also empty in this case.
More info
when I press the Finish button the following is added to the log
I may have been using an old jre in my previous test this is the log
using the jre in j2sdk1.4.1_01 which I believe is the most recent.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
!ENTRY org.eclipse.ui 4 4 Feb 26, 2004 16:10:05.358
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 Feb 26, 2004 16:10:05.358
!MESSAGE Unresolved compilation problem:
Class must implement the inherited abstract method
NewElementWizard.getSchedulingRule()
!STACK 0
java.lang.Error: Unresolved compilation problem:
at
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizar
d.getSchedulingRule(NewVisualClassCreationWizard.java:41)
at
org.eclipse.jdt.internal.ui.wizards.NewElementWizard.perform Finish
(NewElementWizard.java:107)
at org.eclipse.jface.wizard.WizardDialog.finishPressed
(WizardDialog.java:608)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed
(WizardDialog.java:321)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected
(Dialog.java:402)
at org.eclipse.swt.widgets.TypedListener.handleEvent
(TypedListener.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:2352)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2033)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:643 )
at org.eclipse.jface.window.Window.open(Window.java:623)
at org.eclipse.ui.internal.ide.NewWizardShortcutAction.run
(NewWizardShortcutAction.java:98)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:550)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:502)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
(ActionContributionItem.java:435)
(Display.java:2352)
(Display.java:2033)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1566)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1542)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:263)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:139)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:47)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:256)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:100)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
| Re: Install Problems [message #582562 is a reply to message #20769] |
> Problem:
> restart
> new/visual class
> Andre
> \javaw.exe
More info
!STACK 0
at
at
(Dialog.java:402)
(Display.java:2352)
(Display.java:2033)
at
(Display.java:2352)
(Display.java:2033)
| Re: Install Problems [message #582582 is a reply to message #20850] |
Thu, 26 February 2004 16:38  |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
We found the problem last night and it is fixed in today's build. I20040226
Thanks, Rich Kulp
| Re: Install Problems [message #582604 is a reply to message #20863] |
Thu, 26 February 2004 16:39  |
Thanks, Rich Kulp
| Re: Install Problems [message #582708 is a reply to message #20876] |
@eclipse.org:
not.
FUDForum. Page generated in 0.06644 seconds
