Home » Language IDEs » C / C++ IDE (CDT) » Immediate Error Message on Makefile Project Build
Immediate Error Message on Makefile Project Build [message #206968] Wed, 19 December 2007 16:35 Go to next message
I just recently upgraded to Eclipse Europa (3.3.1.1) and CDT (4.0.2) on
Windows. Beforehand, we were using 3.2 of Eclipse and an older version
(don’t recall) of CDT on Solaris.
I am doing embedded development using VxWorks 5.4 and Tornado 2.0.2. I
created a standard make project using the “no tool chain option”. I added
all the requisite environment variables to get our makefiles working.
However, when I attempt to build, my console displays only the following:
**** Build of configuration Default for project xxxxxx ****
(Exec error:The system cannot find the file specified)
There isn’t any additional information in the Problems tab. I’ve been
pulling my hair out trying to figure out what this could possibly mean. I
know my environment settings are OK since I am able to use the values in a
shell and build without a problem.
Re: Immediate Error Message on Makefile Project Build [message #206986 is a reply to message #206968] Thu, 20 December 2007 03:34 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
My guess is that it can't find 'make'.
Derek
> (don?t recall) of CDT on Solaris.
> created a standard make project using the ?no tool chain option?. I
> added all the requisite environment variables to get our makefiles
> working. However, when I attempt to build, my console displays only the
> following:
> There isn?t any additional information in the Problems tab. I?ve been
> I know my environment settings are OK since I am able to use the values
> in a shell and build without a problem.
Re: Immediate Error Message on Makefile Project Build [message #207093 is a reply to message #206986] Mon, 24 December 2007 00:42 Go to previous messageGo to next message
Originally posted by: joshd.msu.edu
Make is in the path variable. Is there any way to get additional
information on the message?
Re: Immediate Error Message on Makefile Project Build [message #207100 is a reply to message #207093] Mon, 24 December 2007 02:22 Go to previous messageGo to next message
Look in the log.
workspace/.metadata/.log
Derek
Re: Immediate Error Message on Makefile Project Build [message #207592 is a reply to message #207100] Mon, 07 January 2008 11:29 Go to previous messageGo to next message
After thinking that this may be an installation issue with CDT and the
Java EE version of Eclipse, I installed the preconfigured "C++ IDE"
edition and created a brand new workspace and project (using the same
settings). I am still receiving a similar error:
****Buid of configuration Default for project xxxxxxx ****
make all
fatal error in make: The system cannot find the file specified
make *** [all] Error 0x2
This is pretty similar to the old error:
The primary difference is that now instead of being an "Exec" error, it is
a make error. The other odd thing is that with my new installation, the
log file under workspace/.metadata is not being created. Previously,
there were a bunch of exceptions that I though indicated a configuration
issue, which is what prompted me to get the C++ edition after
unsuccessfully trying to get the CDT master to install as a local archive.
Re: Immediate Error Message on Makefile Project Build [message #207600 is a reply to message #207592] Mon, 07 January 2008 14:20 Go to previous message
> a make error.
If you run make with the -d option it should produce a detailed output
that shows what's wrong.
Dave
Previous Topic:update manager vs. unzipping
Next Topic:Header File Template?
Current Time: Sat Jul 26 20:04:26 EDT 2025
Powered by FUDForum. Page generated in 0.05475 seconds
