Home » Language IDEs » ServerTools (WTP) » Including a JSP from an other projects
Including a JSP from an other projects [message #207460] Fri, 25 January 2008 14:38 Go to next message
Originally posted by: fredds.programmer.net
I'm working on a big Web application that have been split into several Web
projects under Eclipse.
Let say I have a "Common" project with a "/MyApp/Common.jsp" page.
I also have a "CustomerProfile" project with a JSP page that includes
"/MyApp/Common.jsp".
The problem is the JSP validator says:
"Fragment 'Common.jsp' was not be found at expected path
"/Common/MyApp/Common.jsp"
Is there a way to specify from which paths the JSP validator must search
JSP files? Like it's done for Java source where we can specify links to
other projects...
Fred
Re: Including a JSP from an other projects [message #207582 is a reply to message #207460] Mon, 28 January 2008 13:18 Go to previous message
> Web projects under Eclipse.
> other projects...
The validator is relying on the project's
..settings/org.eclipse.wst.common.component file to help determine
where fragments are located in your Dynamic Web Project. I am not
an authority on the contents and layout of that file, but I'm fairly
sure that directly referencing resources between projects is not
supported.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Previous Topic:plugins installed but class not found
Next Topic:Tomcat with Eclipse.
Current Time: Thu Sep 04 03:24:13 EDT 2025
Powered by FUDForum. Page generated in 0.07735 seconds
