Remove the horizontal line in the middle of Compartment? [message #207149] |
Fri, 26 September 2008 07:00  |
in compartments there is a horizontal line above which stays the Label of
the compartment. Normally this line is just under the Label, but somehow
it happened to me that the line now is in the middle of the compartment.
And now the compartments are divided in upper (empty) and bottom (where
elements are added) part, but I would like them as before.
Here is a picture of a compartment:
http://posithing.com/temp/pics/gmf-line-in-the-middle.bmp
You can see that after an element is added to the compartment, the line
moves upwards.
Do you what could be the reason for it and how can I make the line just
stays under the label? The problem is not in the "List Layout" property.
I'm using Eclipse 3.4.0 and GMF SDK 2.1.0 and GMF Runtime 1.1.0
Greetings,
Nikolay
Re: Remove the horizontal line in the middle of Compartment? [message #207164 is a reply to message #207149] |
Fri, 26 September 2008 07:40   |
Hi Nikolay,
had the same issue, when I moved from GMF 2.0 (or some Milestone of 2.1) to
GMF 2.1.
In your grafdef-model make sure, you set the correct layouts and constraints
for your elements:
My Figure, that looks like yours has the following definition:
RoundedRectangle XXX
- BorderLayout
- Label XXXLabel
- BorderLayoutData Beginning (vertical is set to true)
- Rectangle XXXCompartment
- BorderLayoutData Center (vertical is also set to true)
- Child Access (... for label)
- Child Access (... for comparment)
should do the trick for you.
HTH
Thomas
"Nikolay Georgiev" <erdtek@gmail.com> schrieb im Newsbeitrag
news:0b9cbfc4806cef3d36a373cb0e3abcdd$1@www.eclipse.org...
> Hello,
> moves upwards.
> Greetings,
> Nikolay
FUDForum. Page generated in 0.24120 seconds
