Home » Archived » BIRT » Extracting the resultset problem.
Extracting the resultset problem. [message #207522] Wed, 20 December 2006 02:30 Go to next message
I am trying to extract the result sets from the reportdocument file by using
IDataExtraction task. The sql query contains 3 columns as part of select.
However, when I iterate through the resultset to print the data, I only get
one column. Is the resultset dependent on which table it's bound to in the
designer? Here is my sample code:
IReportDocument iReportDocument = engine.openReportDocument(reportDocument);
//Create Data Extraction Task
IDataExtractionTask iDataExtract =
engine.createDataExtractionTask(iReportDocument);
//Get list of result sets
ArrayList resultSetList =
(ArrayList)iDataExtract.getResultSetList( );
if (resultSetList.size() > 0) {
for (int rIndex = 0; rIndex < resultSetList.size(); rIndex++ ) {
IResultSetItem resultItem =
(IResultSetItem)resultSetList.get(rIndex);
String dispName = resultItem.getResultSetName( );
iDataExtract.selectResultSet( dispName );
IExtractionResults iExtractResults = iDataExtract.extract();
try {
if ( iExtractResults != null ) {
IDataIterator iData =
iExtractResults.nextResultIterator( );
IResultMetaData metaData =
iData.getResultMetaData();
int numberOfCols = metaData.getColumnCount();
//iterate through the results
if ( iData != null ) {
while (iData.next( )) {
for (int i=0; i < numberOfCols; i++) {
System.out.println((iData.getValue(i));
iData.close();
}catch( Exception e){
Logging.error("Error ", e);
iDataExtract.close();
Though the sql statement contains 3 columns, while designing the report, I
create complex groupby aggregation etc. Does it affect the resultset?
Any help would be appreciated. Is there anyother way, where I can access the
resultsets?
Re: Extracting the resultset problem. [message #207920 is a reply to message #207522] Wed, 20 December 2006 22:26 Go to previous messageGo to next message
Data Extracts work on report items, so if you want the whole sql resultset
available bind it to a table. You dont display the values.
Jason
"Bidyut Pattanayak" <bidyut@yahoo.com> wrote in message
news:emaorl$rvr$1@utils.eclipse.org...
> using IDataExtraction task. The sql query contains 3 columns as part of
> select. However, when I iterate through the resultset to print the data, I
> only get one column. Is the resultset dependent on which table it's bound
> to in the designer? Here is my sample code:
> try {
> iData.close();
> the resultsets?
> Thanks
Re: Extracting the resultset problem. [message #208079 is a reply to message #207920] Thu, 21 December 2006 14:32 Go to previous message
Thanks. That's what I was assuming.
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:emcust$95k$1@utils.eclipse.org...
> Jason
>> Hi,
>> I only get one column. Is the resultset dependent on which table it's
>> bound to in the designer? Here is my sample code:
>> try {
>> iData.close();
>> I create complex groupby aggregation etc. Does it affect the resultset?
>> the resultsets?
>> Thanks
Previous Topic:Update Troubles
Next Topic:Security for BIRT viewer in J2EE web app
Current Time: Tue Jul 22 14:26:52 EDT 2025
Powered by FUDForum. Page generated in 0.05913 seconds
