Home » Modeling » GMF (Graphical Modeling Framework) » Properties View -- GMF 2.1
Properties View -- GMF 2.1 [message #206513] Tue, 23 September 2008 06:08 Go to next message
Originally posted by: xxx.xxxxxxxx.xxx
Hallo,
Can someone point me to a good documentation regarding Properties View for
GMF 2.1?
In short... GMF 2.1, in gmfgen, I want to customize the Properties View
and define one tab, containing multiple sections.
In long... in gmfgen, I create Property Sheet -> Custom Property Tab (and
specify its human readable label T_HRL, identifier T_ID and implementation
class T_IMPL) and its Typed selection filter.
When I generate the diagram code from gmfgen, the result is the following:
In plugin.xml, there is one additional propertyTab, and one additional
propertySection which class is T_IMPL, i.e. the implementation class of
the tab from gmfgen, and T_IMPL extends AdvancedPropertySection. This
means, for each tab in gmfgen, the generator creates one tab with exactly
one section. This means, relationship between tab:section is 1:1, but not
1:n - the way it is supposed to be :)
I have no problem doing this in the generated diagram plugin.xml... but
every time I re-generate from gmfgen, my manually added tabs/sections in
plugin.xml are lost.
It would be best if someone could refer me to a good documentation
regarding customizing properties view in gmfgen for GMF 2.1.
Kind regards,
Iliyana Ivanova
Re: Properties View -- GMF 2.1 [message #206553 is a reply to message #206513] Tue, 23 September 2008 06:50 Go to previous messageGo to next message
Hello Iliyana,
> relationship between tab:section is 1:1, but not 1:n - the way it is
> supposed to be :)
You are right. The only way to associate more then one section with same
property tab (as it is generated for "property.tab.AppearancePropertySection"
tab) is to modify generated plugin.xml / template for plugin.xml generation.
You can either modify corresponding template or protect particular top-level
tag in plugin.xml from following code generation by writing <?gmfgen generated="false"?>
there.
Alex Shatalin
Re: Properties View -- GMF 2.1 [message #207198 is a reply to message #206553] Sat, 27 September 2008 11:51 Go to previous messageGo to next message
Hello Alex,
thank you for the quick answer. I'm using the first possibility for the
time being (<?gmfgen generated="false"?>) and it works ok.
Do you know whether it's been planned for GMF to support the tabbed
properties view, as described by Anthony Hunter's article
http://www.eclipse.org/articles/Article-Tabbed-Properties/ta bbed_properties_view.html
Kind regards,
Iliyana Ivanova
Alex Shatalin wrote:
> Hello Iliyana,
>> supposed to be :)
generated="false"?>
> there.
> Alex Shatalin
Re: Properties View -- GMF 2.1 [message #207232 is a reply to message #207198] Mon, 29 September 2008 06:21 Go to previous messageGo to next message
Hello Iliyana,
> rties_view.html ?
We have no estimations for this task now..
Alex Shatalin
Re: Properties View -- GMF 2.1 [message #207347 is a reply to message #207232] Mon, 29 September 2008 10:15 Go to previous messageGo to next message
Hello Alex,
ok, thanks for your help.
Kind regards,
Iliyana
> Hello Iliyana,
>> rties_view.html ?
> Alex Shatalin
Re: Properties View -- GMF 2.1 [message #207409 is a reply to message #206513] Mon, 29 September 2008 23:07 Go to previous messageGo to next message
"Iliyana Ivanova" <xxx@xxxxxxxx.xxx> wrote in message
news:c2833fed68897361601199f629f137bf$1@www.eclipse.org...
Hi Iliyana,
Have you considered adding your additional extension points in a separate
plug-in? Generated code in one plug-in, your additional / overriding /
customized extension points in another.
Cheers...
Anthony
Re: Properties View -- GMF 2.1 [message #207451 is a reply to message #207409] Tue, 30 September 2008 05:09 Go to previous message
Hallo Anthony,
I haven't really thought about having a clear separation between the
generated gmf code and the customized code, and I think this is actually
impossible in my case.
My business model is complex and can not be handled by GMF, so I have
created an intermediate business model via some transformations.. and I
can not really keep the generated GMF code as is, because I have to do a
lot of customization to keep the integrity between the original and
intermediate business models. That's why I have decided to keep everything
in one plugin.
Kind regards,
Iliyana
> Hi Iliyana,
> Cheers...
> Anthony
Previous Topic:error about label attributes
Next Topic:Remove the border of a compartment
Current Time: Wed Jul 23 07:28:04 EDT 2025
Powered by FUDForum. Page generated in 0.05305 seconds
