Home » Modeling » GMF (Graphical Modeling Framework) » Creation of a node without link to the model
Creation of a node without link to the model [message #207434] Tue, 30 September 2008 04:55 Go to next message
I would like to create a node that is purely graphic, not linked to the
model. for example exactly as your Note element.
How can I do that?
I have an idea :
- create a mapping with a element of the model, and then modify the
generated code and remove the link to the model and add another id.
Patrick
Re: Creation of a node without link to the model [message #207443 is a reply to message #207434] Tue, 30 September 2008 05:08 Go to previous messageGo to next message
Hello Patrick,
You can create .gmfmap file without any references to the domain model. As
a reault you should have "pure notation" diagram.
Alex Shatalin
Re: Creation of a node without link to the model [message #207712 is a reply to message #207443] Thu, 02 October 2008 09:04 Go to previous messageGo to next message
I created a TopNode Reference , there are no references at children feature
and containment feature.
then a create a node mapping where I reference only :
-related diagrams
-Diagram node
-tool.
The validation of thegmf map is ok but at the generation the following
message is displayed: "Errors while creating generator model".
There is nothing in the log.
"Alex Shatalin" <vano@borland.com> a
Re: Creation of a node without link to the model [message #207735 is a reply to message #207712] Thu, 02 October 2008 10:56 Go to previous messageGo to next message
Hi Patrick,
do you have any link mappings referring to a model element? There is a
bug in GMF:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=219409
Maybe you could vote for it?
Matthias
Patrick Tessier wrote:
> -related diagrams
> -Diagram node
> -tool.
> "Alex Shatalin" <vano@borland.com> a écrit dans le message de news:
> 3c3172e6270cb8caf103f414ba46@news.eclipse.org...
>> Hello Patrick,
>> Alex Shatalin
Re: Creation of a node without link to the model [message #207766 is a reply to message #207735] Fri, 03 October 2008 03:52 Go to previous message
Patrick
"Matthias Erche" <erche@ikv.de> a
Previous Topic:save button is not enable
Next Topic:Constraint problem (one instance constraint)
Current Time: Fri Jul 25 19:52:54 EDT 2025
Powered by FUDForum. Page generated in 0.04098 seconds
