Home » Language IDEs » ServerTools (WTP) » Adding a server to eclipse
Adding a server to eclipse [message #207284] Tue, 22 January 2008 11:33 Go to next message
Originally posted by: massimiliano.fanciulli.intecs.it
Hi All,
i'm searching documentation for extending the
org.eclipse.wst.server.core.* extension points in order to implement a
plugin that will add a new server to Eclipse. I could not find any
useful tutorial that would explain this clearly and i haven't found any
post on this newgroup (actually there are more than 15000 posts to
check! gosh!).
Does anyone have some useful links?
Thank you,
Massimiliano
Re: Adding a server to eclipse [message #207319 is a reply to message #207284] Wed, 23 January 2008 04:04 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Massimiliano,
do you want to do some coding for the new server plugin, or do you want to use
the WTP generic server plugin (as JBoss server does)? If you want to do the
latter, then your work can be done by some configuration files.
For WTP 1.5, I created a modified JBoss plugin which added the EJB3 libraries.
Maybe you can take this plugin file as a sample for your own plugin.
http://www.informatik.fh-wiesbaden.de/~knauf/public/org.ecli pse.jst.server.jboss.ejb3_1.5.0.v200706052200.jar
Best regards
Wolfgang
Massimiliano Fanciulli schrieb:
> Hi All,
> check! gosh!).
> Thank you,
> Massimiliano
Re: Adding a server to eclipse [message #207323 is a reply to message #207319] Wed, 23 January 2008 05:51 Go to previous messageGo to next message
Hi Wolfgang,
i have a product that is a web application shipped with Tomcat. What i
want to do is simply let user add one or more remote servers of that
kind. Eclipse then would let user run/debug some code on these servers.
If i have understood well i can achieve this point simply deriving my
own server from the WTP generic Tomcat server.. Am i right? How can i
specify that my server is not local but remote?
I'll check your code. Thank you for your help.
Massimiliano
Wolfgang Knauf wrote:
> Hi Massimiliano,
> to use the WTP generic server plugin (as JBoss server does)? If you want
> to do the latter, then your work can be done by some configuration files.
> libraries. Maybe you can take this plugin file as a sample for your own
> plugin.
> Best regards
> Wolfgang
>> Hi All,
>> any post on this newgroup (actually there are more than 15000 posts to
>> check! gosh!).
>> Thank you,
>> Massimiliano
Re: Adding a server to eclipse [message #207326 is a reply to message #207323] Wed, 23 January 2008 11:43 Go to previous message
Hi Massimiliano,
Chapter 12 [1] in the WTP book "Eclipse Web Tools Platform: Developing
Java Web Applications" shows in detail how to add custom servers to WTP.
For full disclosure, I'm a co-author of this book.
[1] http://www.eclipsewtp.org/chapter12.html
Lawrence Mandel
Co-author Eclipse Web Tools Platform: Developing Java Web Applications
Previous Topic:Project-> Properties-> Run/Debug ->New ...all blank
Next Topic:Failed to get the xml catalog user specified entries from the eclipse preference
Current Time: Wed Jul 23 02:39:59 EDT 2025
Powered by FUDForum. Page generated in 4.75114 seconds
