| Moveable Connection anchors [message #206726] |
Thu, 05 January 2006 13:34  |
Originally posted by: harsh.ti.com
All,
Is it possible to creat movable connection anchors within a figure? What
I want to do is allow the user to move the anchor along the path of the
outline border of the figure?
Thank you,
Harsh
| Re: Moveable Connection anchors [message #206824 is a reply to message #206814] |
Fri, 06 January 2006 16:02   |
Thank you Hannes.
As for the orientation, it is based on a static pointlist. The graphics
then uses this to fill and draw the polygon. Here is a code snippet..
static {
topConnector.addPoint(-2, 0);
topConnector.addPoint(1, 0);
topConnector.addPoint(2, 1);
topConnector.addPoint(2, 5);
topConnector.addPoint(-1, 5);
topConnector.addPoint(-1, 1);
bottomConnector.addPoint(-2, -1);
bottomConnector.addPoint(1, -1);
bottomConnector.addPoint(2, -2);
bottomConnector.addPoint(2, -6);
bottomConnector.addPoint(-1, -6);
bottomConnector.addPoint(-1, -2);
| Re: Moveable Connection anchors [message #206909 is a reply to message #206845] |
Sun, 08 January 2006 14:38   |
Originally posted by: christian.sell.netcologne.de
I am quite sure Hannes can post the code, if you just wait a little..
el_bosso@gmx.de wrote:
> Look at the ChopBoxAnchor (that's what I did) and try to understand how this
> Anchor works. I added a setLocation method to the anchor and checked the
> given position with the figure border.
> Sorry can't give you any code, 'cause I wrote that for a non Open source
> project.
> Hannes
> Harsh wrote:
>> Hannes,
>> Have you implemented something similar? If so, do you mind sending me a
>> code snippet? Also, don't you have to extend the AbstractConnectionAnchor
>> and in your connection anchor have a setLocation method?
>> Also, ConnectionAnchors must have a figure as their owner. I am assuming
>> the figure then will also have to do the HitTest to see if the new
>> location region matches the outline of your figure correct? Also, do your
>> figures have a border?
>> Thank you,
>> Harsh
FUDForum. Page generated in 0.06149 seconds
