Home » Eclipse Projects » GEF » Draw2d for UML sequence diagram lifelines
Draw2d for UML sequence diagram lifelines [message #206599] Wed, 04 January 2006 08:43 Go to next message
Originally posted by: lars.ehrler.dai-labor.de
I am working on a sequence diagram editor which is able to show diagrams
like UML sequence diagrams. FOr this I wanted to use GEF with Draw2d.
But I cannot find a full coverage documentation for Draw2d.
Especially which figures to use for which purpose would be very helpful.
I have especially problems with rendering the lifelines. I thought I
might be able to use a label together with a polyline, however, this
does not work.
Does anybody has hints to helpful documentation or maybe has already
imlpemented a sequence diagram editor and can give me help ?
Thanks in advance,
Lars Ehrler
Re: Draw2d for UML sequence diagram lifelines [message #206614 is a reply to message #206599] Wed, 04 January 2006 10:20 Go to previous messageGo to next message
Maybe I can solve my problem, however, I need to calculate the size of a
label depending on the text in the label. One might think the method
getTextBounds() is the one I need, but there is an exception:
Exception in thread "main" java.lang.NullPointerException
at org.eclipse.draw2d.FigureUtilities.setFont(FigureUtilities.j ava:369)
at
org.eclipse.draw2d.FigureUtilities.getTextDimension(FigureUt ilities.java:87)
at
org.eclipse.draw2d.FigureUtilities.getTextWidth(FigureUtilit ies.java:205)
at org.eclipse.draw2d.Label.getSubStringText(Label.java:363)
at org.eclipse.draw2d.Label.calculateSubStringTextSize(Label.ja va:231)
at org.eclipse.draw2d.Label.getSubStringTextSize(Label.java:384 )
at org.eclipse.draw2d.Label.calculateLocations(Label.java:158)
at org.eclipse.draw2d.Label.getTextLocation(Label.java:431)
at org.eclipse.draw2d.Label.getTextBounds(Label.java:419)
Does anybody know how to fix this ?
Lars
Lars Ehrler schrieb:
> Hello,
> does not work.
> Thanks in advance,
> Lars Ehrler
Re: Draw2d for UML sequence diagram lifelines [message #206878 is a reply to message #206614] Sun, 08 January 2006 04:09 Go to previous messageGo to next message
Originally posted by: marguu.libero.it
Try this code:
FontData fd =new FontData("Arial",10,SWT.NONE);
font = new Font(null,fd);
Dimension dim = FigureUtilities.getTextExtents("text",font);
Re: Draw2d for UML sequence diagram lifelines [message #229439 is a reply to message #206599] Fri, 19 January 2007 09:42 Go to previous messageGo to next message
Hi Lars,
I have the same problem. I must implement a sequence diagram.
Have you found any example, resources or a solution?
greetings
Andreas Herz
Lars Ehrler wrote:
> Hello,
> does not work.
> Thanks in advance,
> Lars Ehrler
Re: Draw2d for UML sequence diagram lifelines [message #229445 is a reply to message #206599] Fri, 19 January 2007 09:44 Go to previous messageGo to next message
Hi Lars,
greetings
Andreas Herz
Lars Ehrler wrote:
> Hello,
> does not work.
> Thanks in advance,
> Lars Ehrler
Re: Draw2d for UML sequence diagram lifelines [message #229451 is a reply to message #206599] Fri, 19 January 2007 09:46 Go to previous messageGo to next message
Hi Lars,
greetings
Andreas Herz
Lars Ehrler wrote:
> Hello,
> does not work.
> Thanks in advance,
> Lars Ehrler
Re: Draw2d for UML sequence diagram lifelines [message #229456 is a reply to message #206599] Fri, 19 January 2007 09:47 Go to previous messageGo to next message
Hi Lars,
greetings
Andreas Herz
Lars Ehrler wrote:
> Hello,
> does not work.
> Thanks in advance,
> Lars Ehrler
Re: Draw2d for UML sequence diagram lifelines [message #229594 is a reply to message #229456] Mon, 22 January 2007 09:33 Go to previous message
Perhaps you could create a Wrapper figure for the lifeline that will have
two figures as it's children: 1) the rectangle for the lifeline head where
you will add the label to 2) the polyline figure for the rest of the
lifeline.
Hope this helps.
Alex
Previous Topic:How to meaure the string(text) width?
Next Topic:Draw2D Headless
Current Time: Fri Jul 25 15:15:09 EDT 2025
Powered by FUDForum. Page generated in 0.08429 seconds
