Home » Language IDEs » Java Development Tools (JDT) » Modifying setter generation?
Modifying setter generation? [message #205428] Wed, 01 June 2005 15:11 Go to next message
I'd like to add the keyword "final" before the argument in the setter
signature. Is there any way to modify the template to do this?
I see you can check off "final" but that's for the whole method. I want it
to look like this:
public void setFoo(final int foo) {
Otherwise, CheckStyle warns about the variable needing to be final.
Sean LeBlanc
Re: Modifying setter generation? [message #205510 is a reply to message #205428] Thu, 02 June 2005 05:49 Go to previous messageGo to next message
This cannot be specified in the template. There is however a feature request
to introduce a final code generation setting
Cheers
Tobias
"Sean LeBlanc" <seanleblanc@comcast.net> wrote in message
news:d7l1ja$71m$1@news.eclipse.org...
> to look like this:
> Sean LeBlanc
Re: Modifying setter generation? [message #205587 is a reply to message #205510] Thu, 02 June 2005 10:19 Go to previous messageGo to next message
"Tobias Widmer" <tobias_widmer@ch.ibm.com> wrote in message
news:d7mknr$vf3$1@news.eclipse.org...
> request to introduce a final code generation setting
<snip>
Okay, thanks. I should have searched bugzilla first. I think this is what
you were referring to?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=40078
Re: Modifying setter generation? [message #205613 is a reply to message #205428] Thu, 02 June 2005 14:04 Go to previous messageGo to next message
> to look like this:
Does it really? That is simply not true. There is no inherent *need* for
setter arguments to be final. In fact, the only reason I know of to make
a method parameter final is when it is used in the code of a local inner
class.
Seems to me CheckStyle is being too stringent in this case.
Eric
Re: Modifying setter generation? [message #205814 is a reply to message #205587] Fri, 03 June 2005 12:25 Go to previous messageGo to next message
Yes, there is also this one: bug 71748
news:d7n4i5$m6a$1@news.eclipse.org...
> <snip>
Re: Modifying setter generation? [message #205821 is a reply to message #205613] Fri, 03 June 2005 12:27 Go to previous messageGo to next message
This can be configured. Some people just like to express the value semantics
of method argument by using the final keyword.
Tobias
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:d7nhpj$beo$1@news.eclipse.org...
>> it to look like this:
> setter arguments to be final. In fact, the only reason I know of to make a
> class.
> Eric
Re: Modifying setter generation? [message #206861 is a reply to message #205613] Thu, 16 June 2005 10:55 Go to previous message
> class.
> Eric
As Tobias points out, CheckStyle can be configured to ignore this.
However, I like to have this check left on. This is something that is
recommended in _Hardcore Java_, as well, and I think in many cases it makes
sense as a guard against unintended consequences.
Previous Topic:Keybindings lost
Next Topic:Annoying problem with debugger, 3.1RC1, Java 1.5
Current Time: Fri Jul 18 20:11:22 EDT 2025
Powered by FUDForum. Page generated in 0.09695 seconds
