Spaces in Foldernames [message #206755] |
Mon, 14 January 2008 11:32  |
Originally posted by: Juergen.Schwibs.seb.se
would be nice to have a hint in the docs for the following issue, which I
had with current WTP wtp-S-3.0M4-20080105091323, Eclipse
eclipse-SDK-3.4M4-win32 and jboss 4.2:
I installed Eclipse under "c:\Program Files" and JBoss under "c:\JBoss"
(Windows XP). Because of the space in the folder name deploying of code
was not working (Got an java.net.SocketTimeoutException from
RemoteAntBuildListener.java).
After moving Eclipse into a folder without spaces the deploying of code
started to work fine.
Jürgen
Re: Spaces in Foldernames [message #207270 is a reply to message #206766] |
Mon, 21 January 2008 10:48  |
On Mon, 14 Jan 2008 11:38:43 -0500, David Carver <dcarver@starstandard.org> wrote:
> If you haven't already, I would open a bug against this. As it should
> handle spaces correctly by making sure they are a valid URI and encoded
> correctly.
Agreed, please do. And if possible, please test with eclipse having the spaces vs. no-spaces and also JBoss having the spacees-nospaces, and also another server, if possible. It's hard for me to tell where source of the problem is, from your comments. And, guess I'm skeptical that it is in WTP core code as we've had this problem in the past and it was fixed, and would be surprised it's crept back in (in the core code).
FUDForum. Page generated in 0.04500 seconds
