Home » Language IDEs » ServerTools (WTP) » Spaces in Foldernames
Spaces in Foldernames [message #206755] Mon, 14 January 2008 11:32 Go to next message
Originally posted by: Juergen.Schwibs.seb.se
would be nice to have a hint in the docs for the following issue, which I
had with current WTP wtp-S-3.0M4-20080105091323, Eclipse
eclipse-SDK-3.4M4-win32 and jboss 4.2:
I installed Eclipse under "c:\Program Files" and JBoss under "c:\JBoss"
(Windows XP). Because of the space in the folder name deploying of code
was not working (Got an java.net.SocketTimeoutException from
RemoteAntBuildListener.java).
After moving Eclipse into a folder without spaces the deploying of code
started to work fine.
Jürgen
Re: Spaces in Foldernames [message #206766 is a reply to message #206755] Mon, 14 January 2008 11:38 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
If you haven't already, I would open a bug against this. As it should
handle spaces correctly by making sure they are a valid URI and encoded
correctly.
Dave
Juergen Schwibs wrote:
> Hello,
> I had with current WTP wtp-S-3.0M4-20080105091323, Eclipse
> RemoteAntBuildListener.java). After moving Eclipse into a folder without
> spaces the deploying of code started to work fine.
> Jürgen
Re: Spaces in Foldernames [message #206774 is a reply to message #206766] Mon, 14 January 2008 12:04 Go to previous messageGo to next message
David,
Yes, in a URI they should be encoded as %20. Spaces in file names so
often lead to problems. I suppose file names can have other scary
characters like # and that those are just as likely to cause problems.
Lots of folks probably don't realize too that a "\" character is allowed
on many unix OSs...
> encoded correctly.
> Dave
>> Hello,
>> which I had with current WTP wtp-S-3.0M4-20080105091323, Eclipse
>> "c:\JBoss" (Windows XP). Because of the space in the folder name
>> deploying of code was not working (Got an
>> java.net.SocketTimeoutException from RemoteAntBuildListener.java).
>> Jürgen
Re: Spaces in Foldernames [message #207270 is a reply to message #206766] Mon, 21 January 2008 10:48 Go to previous message
On Mon, 14 Jan 2008 11:38:43 -0500, David Carver <dcarver@starstandard.org> wrote:
> correctly.
Agreed, please do. And if possible, please test with eclipse having the spaces vs. no-spaces and also JBoss having the spacees-nospaces, and also another server, if possible. It's hard for me to tell where source of the problem is, from your comments. And, guess I'm skeptical that it is in WTP core code as we've had this problem in the past and it was fixed, and would be surprised it's crept back in (in the core code).
Previous Topic:How to get the xmlcatalog entries from the eclipse preference
Next Topic:Announcing the first milestone of the XSL Incubating Component
Current Time: Sat Jul 26 20:40:48 EDT 2025
Powered by FUDForum. Page generated in 0.03749 seconds
