Versioning questions.. [message #205498] |
Wed, 03 March 2004 15:07  |
How does Eclipse resolve the issue where an extension of the same name/uid
from two different versions of the same plugin, is loaded? Does Eclipse even
care about version information in relation to extension points and
extensions? Or is it only for plugin dependencies that versioning matters?
Does it adopt the versioning of OSGi now, where by the first one found (or
is it the latest version..??) is used and all others are ignored? If so, how
does it handle failures of resolving plugins that do not work against a
version that the OSGi versioning code deems the one to use? For example, a
plugin with ant 1.0 and a plugin with ant 1.2, which ant gets used? It was a
while back I read the OSGi spec in regards to this, but I thought it takes
the latest version of the library? Then again, how does it know what version
a library is? IS it based on the plugin's version information?
Thanks.
Re: Versioning questions.. [message #206972 is a reply to message #206724] |
Sat, 06 March 2004 13:02   |
Originally posted by: p.essi.fr
For every plugin that declares extension, the runtime select one and
only one version of that plugin. Therefore, there is not problem with
extension / extension pointS.
PaScaL
spiderman wrote:
> Nobody knows how versioning works between extension points and extension
> plugins? Is it only for dependencies, or is it enforced at the EP and E
> levels as well?
> "spiderman" <supreme_java_guru_1@yahoo.com> wrote in message
> news:c25dok$as4$1@eclipse.org...
> even
> how
> a
> version
>>Thanks.
Re: Versioning questions.. [message #207025 is a reply to message #206972] |
Sat, 06 March 2004 15:50  |
Is that based on the OSGi core now? I recall the spec says that. But did
Eclipse do it that way prior as well, where only one plugin was selected? If
so, how does the runtime determine which one to choose? How does it avoid
compatibility issues or for that matter when an end user updates one plugin
that no longer works with other plugins the older version used to work with,
does the end user get shafted, or does the runtime revert to the old one, or
what? I thought it could load multiple versions of the same plugin and work
with them all?
I am curious why the built in serialVersionUID stuff to determine compatible
class versioning is not used? Is it too cumbersome for plugin developers to
learn how to use that mechanism?
"Pascal" <p@essi.fr> wrote in message news:c2d3g2$lq1$1@eclipse.org...
> PaScaL
> > levels as well?
name/uid
> > even
matters?
(or
> > how
a
was
> > a
takes
> > version
> >>Thanks.
FUDForum. Page generated in 0.03380 seconds
