Home » Newcomers » Newcomers » All import files being flagged unresolvable
All import files being flagged unresolvable [message #206615] Sun, 22 April 2007 02:47 Go to next message
Originally posted by: mukerji.nita.gmail.com
I had Exclipse 3.2 installed and was doing fine with it.But I dont know
what I did to corrupt it. All import files (that my programs wre doing
fine with) are being flagged as unresolvable/not in use.To fix it I wanted
to remove eclipse and reinstall it afresh. But access is denied.
How do I remove Eclipse?
Re: All import files being flagged unresolvable [message #206633 is a reply to message #206615] Sun, 22 April 2007 04:38 Go to previous messageGo to next message
Eclipse3.2 is installed in windows xp environment
Re: All import files being flagged unresolvable [message #206683 is a reply to message #206615] Sun, 22 April 2007 16:57 Go to previous messageGo to next message
> wanted to remove eclipse and reinstall it afresh. But access is denied.
Are you logged in with the same account that you used when things
worked? The inability to delete Eclipse sounds like a permissions
problem, and a permissions problem might explain the unresolvable error.
If the login account has not changed, you might try starting eclipse
with the -clean option.
/Paul
Re: All import files being flagged unresolvable [message #206690 is a reply to message #206615] Sun, 22 April 2007 17:01 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Nita" <mukerji.nita@gmail.com> wrote in message
news:b22da1577a4587a307b5dc6c1ee50aa4$1@www.eclipse.org...
>what I did to corrupt it. All import files (that my programs wre doing fine
>with) are being flagged as unresolvable/not in use.To fix it I wanted to
Eclipse does not write anything in the registry. An Eclipse installation is
just a set of files. So, if you delete all files under your ...\eclipse
directory, you have uninstalled it; and if you expand the Eclipse zip file
to a new directory, you have installed it. Simple as that. (I guess if you
have installed a bunch of plugins in addition to what comes with the Eclipse
SDK, you would have to reinstall those too, using whatever means you
installed them with before, e.g., update site.)
You don't even really have to uninstall. You can just make a new Eclipse
installation in a different directory, and try that one. I probably have
six different versions of Eclipse installed on my machine right now.
If this doesn't match what you're experiencing, please be more precise about
what you mean by "access is denied".
Re: All import files being flagged unresolvable [message #206735 is a reply to message #206615] Sun, 22 April 2007 17:19 Go to previous messageGo to next message
Removing Eclipse is just a matter of deleting the directory it is
installed into, but there is almost never a need to uninstall and
re-install Eclipse.
Your problem sounds like a mis-configured project, but it is not clear
to me what symptom you are seeing exactly. Can you provide more details?
Hope this helps,
Eric
Re: All import files being flagged unresolvable [message #206741 is a reply to message #206735] Mon, 23 April 2007 01:06 Go to previous message
Thank you for solving my problem
Previous Topic:bootclasspath
Next Topic:anybody can pl solve this
Current Time: Tue Jul 22 04:53:48 EDT 2025
Powered by FUDForum. Page generated in 0.43146 seconds
