Home » Modeling » GMF (Graphical Modeling Framework) » Can an attribute refer to two ecore reference objects?
Can an attribute refer to two ecore reference objects? [message #20662] Wed, 16 August 2006 08:03 Go to next message
How can i design an Ecore model to have an attribute refer to multiple
ecore objects?
For example:
<menu id="main_menu">
<choice next="#menu1"/>
<choice next="#form1"/>
</menu>
<menu id="menu1">
<choice next="#menu3"/>
<choice next="#menu4"/>
</menu>
<form id="form1">
</form>
I would like to represent the values of next attribute as connections in
the editor.
Is there a way to associate two references to the same attribute? What
could be the strategy to approach this problem?
Thanks in Advance
-Balraj
Re: Can an attribute refer to two ecore reference objects? [message #20705 is a reply to message #20662] Wed, 16 August 2006 08:55 Go to previous messageGo to next message
--------------080601070401030605080104
Balraj,
The schema in the EMF Library schema tutorials has references between
Books and Authors. Maybe that answers your question (which I don't
quite understand):
< http://www.eclipse.org/emf/docs.php?doc=tutorials/xlibmod/xl ibmod.html>
The mindmap model as similar examples of cross references.
Balraj Kannan wrote:
> multiple ecore objects?
> For example:
> </menu>
> <menu id="menu1">
> </menu>
> <form id="form1">
> </form>
> in the editor.
> Thanks in Advance
> Regards,
> -Balraj
<html>
<head>
http-equiv="Content-Type">
</head>
Balraj,<br>
<br>
Books and Authors.
Re: Can an attribute refer to two ecore reference objects? [message #21818 is a reply to message #20705] Thu, 17 August 2006 00:21 Go to previous messageGo to next message
Hi Merks,
Thanks for your reply.
My doubt was slightly different. I have an attribute say next in the
choice element. This can refer to one of the two elements say form or
menu. I am under confusion of how to link one attribute with two
references.
Any suggestions...
Thanks in Advance
Balraj
Re: Can an attribute refer to two ecore reference objects? [message #22043 is a reply to message #21818] Thu, 17 August 2006 05:15 Go to previous messageGo to next message
Hi Balraj,
if form and menu share a common supertype -> no problem.
If not, they at least share EObject as common supertype.
Jan
Balraj Kannan schrieb:
> Hi Merks,
> Thanks for your reply. My doubt was slightly different. I have an
> attribute say next in the choice element. This can refer to one of the
> two elements say form or menu. I am under confusion of how to link one
> attribute with two references.
> Any suggestions...
> Thanks in Advance
> Regards
> Balraj
Re: Can an attribute refer to two ecore reference objects? [message #22902 is a reply to message #22043] Fri, 18 August 2006 00:31 Go to previous messageGo to next message
They share EObject as their common supertype. I am facing the problem with
the xsd. I am not sure how to refer to two elements from one attribute.
Below is the sample xsd that I have. Here I have MenuType and FormType
elements. In choice, the attribute next refers to formType element. Now I
want the same element refer to Menuutype also. Is it possible? How can I
do this?
<xsd:complexType name="formType">
</xsd:complexType>
<xsd:complexType name="menuType">
</xsd:complexType>
<xsd:complexType name="choiceType">
<xsd:attribute ecore:reference="formType" name="next">
<xsd:simpleType>
<xsd:list itemType="xsd:anyURI" />
</xsd:simpleType>
</xsd:attribute>
</xsd:complexType>
Thanks & Regards
Balraj
Re: Can an attribute refer to two ecore reference objects? [message #23033 is a reply to message #22902] Fri, 18 August 2006 07:00 Go to previous messageGo to next message
Balraj,
To create an EReference of type EObject use ecore:reference="xsd:anyType".
> with the xsd. I am not sure how to refer to two elements from one
> attribute.
> Now I want the same element refer to Menuutype also. Is it possible?
> How can I do this?
> </xsd:complexType>
> </xsd:complexType>
> <xsd:simpleType>
> </xsd:simpleType>
> </xsd:attribute>
> </xsd:complexType>
> Thanks & Regards
> Balraj
Re: Can an attribute refer to two ecore reference objects? [message #39006 is a reply to message #23033] Tue, 05 September 2006 03:37 Go to previous messageGo to next message
I tried using ecore:reference="xsd:anyType" as suggested by you. But
when I try to create the link between choice and form elements the link
doesn't get created.
I am trying to view the xml model as follows on the graphical editor.
<vxml>
<menu id="1">
<choice id_ref ="#abc"/>
</menu>
<menu id="2">
</menu>
<form id="abc"/>
</vxml>
In the xsd file I have the choice element as the following:
<xsd:attribute ecore:reference="xsd:anyType" name="id_ref"
type="xsd:anyURI"/>
I want the link from choice to be created to form or menu present directly
under the root element which is vxml in my case. Choice is a child element
under the menu tag.
Please suggest... !!!!
Thanks & Regards
Balraj
Re: Can an attribute refer to two ecore reference objects? [message #39380 is a reply to message #39006] Tue, 05 September 2006 08:12 Go to previous messageGo to next message
Balraj,
This does produce the correct model when I tried it, i.e., an EReference
with eType EObject, so the rest of your questions is a GMF one that I
don't know the answer to.
> link doesn't get created.
> <vxml>
> <menu id="1">
> </menu>
> <menu id="2">
> </menu>
> <form id="abc"/>
> </vxml>
> type="xsd:anyURI"/>
> directly under the root element which is vxml in my case. Choice is a
> child element under the menu tag.
> Thanks & Regards
> Balraj
Re: Can an attribute refer to two ecore reference objects? [message #39503 is a reply to message #39380] Tue, 05 September 2006 09:43 Go to previous messageGo to next message
Merk,
When I tried I get the same in the ecore model. But when I try to
create the link in the editor between choice and form element it fails.
for that matter I am unable to create links between any of the elements in
the editor.
What I am wondering is I am trying to create link between choice which is
under menu element and form which is under the root element. will this
cause any issue?
Thanks a lot for your support..
Balraj
Re: Can an attribute refer to two ecore reference objects? [message #39755 is a reply to message #39503] Tue, 05 September 2006 11:17 Go to previous messageGo to next message
Balraj,
If you attach your .ecore and .gmfmap file (stripped down to appropriate
elements, of course), we could try to figure out why link creation fails.
Artem
"Balraj Kannan" <balraj.kannan@hp.com> wrote in message
news:a7d9cfac5e36c664bd573e25c72f34ec$1@www.eclipse.org...
> Merk,
> When I tried I get the same in the ecore model. But when I try to create
> the link in the editor between choice and form element it fails. for that
> matter I am unable to create links between any of the elements in the
> editor.
> cause any issue?
> Regards
> Balraj
Re: Can an attribute refer to two ecore reference objects? [message #40207 is a reply to message #39755] Wed, 06 September 2006 01:27 Go to previous messageGo to next message
Hi Artem,
Thanks for your reply, I use the web interface to connect to the news
group. I am behind the firewall and unable to configure the outlook
express to connect to the news group. With web interface there is no
option available to attach any files :(. May I request you to kindly
provide me with your email ID to which I can mail my gmf map and ecore
files.
Thanks in Advance,
Balraj
Re: Can an attribute refer to two ecore reference objects? [message #40627 is a reply to message #40207] Wed, 06 September 2006 06:56 Go to previous message
I believe your post "Can a link refer to two notational model in GMF?" from
Sep 05 is about the same issue, so feel free to attach the models to the
request tracking the issue,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156223
Artem
news:de4cca79f1ea80aa7c88764fbc2d48a8$1@www.eclipse.org...
> Hi Artem,
> files.
> Thanks in Advance,
> Regards,
> Balraj
Previous Topic:Internal Error while generating *.gmfgen. what does it mean?
Next Topic:Limits of GMF
Current Time: Tue Nov 04 07:10:57 EST 2025
Powered by FUDForum. Page generated in 0.05699 seconds
