Home » Eclipse Projects » Eclipse Platform » How enable only my plugin at eclipse startup?
How enable only my plugin at eclipse startup? [message #206469] Fri, 05 March 2004 05:25 Go to next message
I have written my own eclipse plugins and I would like this plugin as
default plugin when Eclipse startup. How can I do that without refactoring
eclipse ?
If there is no way to do that, how can I enable my plugin at startup ?
Is there a plugins boot list somewhere ?
Sorry if this is not the good newsgroup for such a question !
Thanks.
Re: How enable only my plugin at eclipse startup? [message #206538 is a reply to message #206469] Fri, 05 March 2004 09:20 Go to previous messageGo to next message
Originally posted by: manahan.NOSPAM.ca.ibm.com
What do you mean by default plugin at startup? Are you writing an tool
for eclipse or a complete product based on eclipse? The answer changes
depending upon what you want to do.
Peter
strus wrote:
> eclipse ?
> Thanks.
Re: How enable only my plugin at eclipse startup? [message #206570 is a reply to message #206469] Fri, 05 March 2004 10:13 Go to previous messageGo to next message
You can edit the list of plugins through the platform.xml (in 3.0 M8) or
platform.cfg (up to 3.0 M8). You would want to set the policy to
USER-INCLUDE and put your plugin in the list attribute of the site
element. I have a feature request concerning simplifying this at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=53858
strus wrote:
> eclipse ?
> Thanks.
Re: How enable only my plugin at eclipse startup? [message #206644 is a reply to message #206538] Fri, 05 March 2004 12:05 Go to previous messageGo to next message
> Peter
> strus wrote:
>> Hi,
>> refactoring
>> eclipse ?
>> Thanks.
I am writting a plugin with a view and perspective and I would like to
enable this perspective at eclipse startup. So the user do not have to
search the plugin in the perspective list.
Thanks.
Re: How enable only my plugin at eclipse startup? [message #206649 is a reply to message #206570] Fri, 05 March 2004 12:09 Go to previous messageGo to next message
> strus wrote:
>>Hi,
>>eclipse ?
>>Thanks.
The issue I see with this solution is that the platform.cfg file is
generated in the .metadata file. So the user has to launch eclipse 1
time then modify the cfg file ... It is not user friendly.
I would prefer do that programmatically in the code of my plugin !
Re: How enable only my plugin at eclipse startup? [message #206716 is a reply to message #206644] Fri, 05 March 2004 14:38 Go to previous message
> Thanks.
So in this case its a tool not a product (product implies you ship your
own version of eclipse and can control its launch).
There isn't anyway way to do it as an extension to an eclipse instance
currently.
If what you want to provide is information on the nifty new plugin they
just installed you can use a welcome page. Search the help for
"welcome page".
Peter
Previous Topic:[Howto] add Separator via plugin.xml to popup-menu?
Next Topic:how to limit the size of view in eclipse platform
Current Time: Thu Sep 25 18:23:04 EDT 2025
Powered by FUDForum. Page generated in 0.04188 seconds
