Home » Eclipse Projects » GEF » Small palette problem
Small palette problem [message #206544] Tue, 03 January 2006 05:11 Go to next message
Originally posted by: greg.gigon.tugulu.com
Hello guys,
I gues that my problem is very simple to solve, but I can't find solution :(
When my palette has more entries, elements disappear under properties view. They are ther but it's
impossible to see it. I'd like to do smething similar to Logic Example where palette adds arrows for
scrolling betwean elements within palette.
Is this some sort of PaletteDrawer property or maybe PaletteGroup?
Cheers, Greg
Re: Small palette problem [message #206629 is a reply to message #206544] Wed, 04 January 2006 12:18 Go to previous messageGo to next message
Hello Guys,
Any IDEAS ??
Greg
Greg wrote:
> Hello guys,
> solution :(
> view. They are ther but it's impossible to see it. I'd like to do
> Cheers, Greg
Re: Small palette problem [message #206676 is a reply to message #206629] Thu, 05 January 2006 02:20 Go to previous messageGo to next message
Originally posted by: ingo.koch[nospam].sap.com
Hi Greg,
did i get you right that you are using a PaletteDrawer as container for your
entries?
If not, yould should do so!
Regards, Ingo
"Greg" <greg.gigon@tugulu.com> wrote in message
news:dph024$gp7$1@utils.eclipse.org...
> Hello Guys,
> Any IDEAS ??
> Greg
> Greg wrote:
> > Hello guys,
> > solution :(
> > Cheers, Greg
Re: Small palette problem [message #206682 is a reply to message #206676] Thu, 05 January 2006 04:05 Go to previous messageGo to next message
I'm using GraphicalEditorWithFlyOutPalette as my editor.
Then I override getPaletteRoot() method in Editor Class.
Next step is to create PaletteRoot. I'm building it using PaletteGroup and PaletteDrawers and
PaletteEntries.
And answer for your question is Yes, I'm using PaletteDrawers as container for my Entries.
My question is how to make nice scroll buttons as it is on Logic Example. When there is too much
elements to show it on palette and there's small black arrow on top and bottom that you can use for
scroll purpose.
Regards, Greg
Ingo Koch wrote:
> Hi Greg,
> entries?
> Regards, Ingo
>>Hello Guys,
>>Any IDEAS ??
>>Greg
>>Greg wrote:
>>>Hello guys,
>>>solution :(
>>>Cheers, Greg
Re: Small palette problem [message #206718 is a reply to message #206682] Thu, 05 January 2006 13:05 Go to previous messageGo to next message
Originally posted by: harsh.ti.com
Greg,
I am doing the same thing you are and it works for me. The fancy arrows
are built-in by GEF. Maybe Randy or Partik have some ideas.
Harsh
Re: Small palette problem [message #206744 is a reply to message #206718] Fri, 06 January 2006 04:51 Go to previous messageGo to next message
I hope he speak finally :D
If that thing is build in GEF I'm wonder what can couse it to disable?
Greg
Harsh wrote:
> Greg,
> Harsh
Re: Small palette problem [message #206958 is a reply to message #206682] Mon, 09 January 2006 11:22 Go to previous messageGo to next message
It should be working. You aren't putting drawers inside a group are you?
What about overriding the way the palette's canvas is placed. Could it be
that the canvas is actually bigger than what is visible?
Re: Small palette problem [message #207038 is a reply to message #206958] Tue, 10 January 2006 04:37 Go to previous message
Hello Randy.
Yes, I'm placing drawers inside group. I'm creating two groups, one is for tools (selection,
connection) and one is for drawers with elements.
I just added drawers to palette root, without putting it in group and everything works fine.
Thanks for good trace Randy :)
Greg
Previous Topic:"Delete" & "Zoom" in MultiPageEditor
Next Topic:Starting out
Current Time: Fri Jul 18 01:54:22 EDT 2025
Powered by FUDForum. Page generated in 0.07664 seconds
