about parameter group [message #20552] |
Fri, 18 March 2005 01:42  |
Originally posted by: eros.design.gmail.com
hi,
could someone tell me what is parameter group, is it just a parameter
'folder' or with some special function in it???
BTW, when will BIRT release help documentation?
thanks
Chan
www.chinaui.org
Re: about parameter group [message #22186 is a reply to message #22144] |
Tue, 22 March 2005 21:14  |
sorry, means user interface/graphic designer and usability engineer.
On Tue, 22 Mar 2005 10:30:05 -0800, Paul Rogers <progers@actuate.com> =
wrote:
> Can you explain "UID/UE" a bit? I'm not quite sure what these mean in =
> this
> context.
> - Paul
> Paul Rogers
> BIRT PMC
> "eros_chan" <eros.design@gmail.com> wrote in message
> news:opsn0vhikp66h8ge@chenke...
> thanks veru much. is there any UID/UE guys need for this project?
> On Fri, 18 Mar 2005 10:15:18 -0800, Paul Rogers <progers@actuate.com>
> wrote:
>> Yes, a parameter group is just a UI folder. The idea here is that som=
e
>> reports provide a large number of prameters. Grouping them helps =
>> organize
>> the parameter entry UI. A UI could use the grouping info to, for =
>> example,
>> keep a "rarely-used" parameter group collapsed until the user needs =
>> those
>> particular parameters.
www.chinaui.org
FUDForum. Page generated in 0.03867 seconds
