Home » Language IDEs » C / C++ IDE (CDT) » Project properties -> paths and symbols
Project properties -> paths and symbols [message #204760] Tue, 13 November 2007 04:41 Go to next message
Originally posted by: mba.cosmigo.ru
I've been wondering for a while, what is the meaning of tabs under
Project properties -> C/C++ General -> Paths and symbols?
I can think out meaning for a few of them, but still there are lots of
questions:
* Includes - here one should list all the locations of external headers
which should be accessible via #include <..> command. Is it so? Is it
used from managed build or for indexer? Does one have to explicitly add
there all subdirectories or just a top dir is enough? What's about
different languages here?
* Symbols - declaring external preprocessor defines?
* Libraries - ?
* Library paths - ?
Why having two tabs? Used only for managed build? Does something with
parser?
* Source location - ???
* Output location - ???
No idea at all how this should be used.
* References - seems to show what projects are referenced but current
project. I've been thinking that marking project as referenced would add
things it exports (listed in Export settings section) to my current
project, but this does not happen. What is the meaning of
C/C++ General -> Export settings??
Can someone clarify this issues. We are mostly interested in making
indexer working better with our project, but any other information would
be appreciated.
Best regards
Mikhail Barg
ICQ: 132560784
Re: Project properties -> paths and symbols [message #205221 is a reply to message #204760] Tue, 20 November 2007 04:22 Go to previous messageGo to next message
Nothing still on this. Is it too lame question to ask?
Mikhail Barg wrote:
> Hello,
Best regards
Mikhail Barg
ICQ: 132560784
Re: Project properties -> paths and symbols [message #206150 is a reply to message #205221] Thu, 06 December 2007 06:16 Go to previous messageGo to next message
Still nothing..... Oh boy...
Mikhail Barg wrote:
> Mikhail Barg wrote:
>> Hello,
Best regards
Mikhail Barg
ICQ: 132560784
Re: Project properties -> paths and symbols [message #206187 is a reply to message #204760] Fri, 07 December 2007 02:56 Go to previous messageGo to next message
Not a lame question :)
Here you can define directories that contain source files. It is also
possible to exclude folders. You only need to change here something if you
want to exclude certain folders (e.g. a doc folder) so it will not get
parsed or you want to add linked folders that are outside of your eclipse
workspace.
Here you can specify where eclipse should look for binaries for running or
debugging. A managed project will deposit your compiled binaries here.
> project.
Here you should list e.g. projects that contain self-build libraries that
are needed to link your application. Every project listed here will be
build *before* the actual project.
Axel
Re: Project properties -> paths and symbols [message #206193 is a reply to message #206187] Fri, 07 December 2007 04:43 Go to previous messageGo to next message
Hello Axel,
Thanks for you answer! I've finally got a response! Wow! ;)
> you want to exclude certain folders (e.g. a doc folder) so it will not
> get parsed or you want to add linked folders that are outside of your
> eclipse workspace.
So if I have a project with following structure:
project_root/
|->bin/
|->src/
|->tools/
I should somehow focus it on /src dir?
>> project.
> that are needed to link your application. Every project listed here will
> be build *before* the actual project.
But what's about Export? I've been thinking that marking project as
referenced would add things it exports (listed in Export settings
section) to my current project, but this does not happen. What is the
meaning of C/C++ General -> Export settings??
Best regards
Mikhail Barg
ICQ: 132560784
Re: Project properties -> paths and symbols [message #206216 is a reply to message #206187] Fri, 07 December 2007 06:19 Go to previous messageGo to next message
Originally posted by: raimund.berger.invalid.dot.com
aegges@web.de (Axel Mueller) writes:
>> current project.
> will be build *before* the actual project.
References are a feature I didn't find that well documented, given I
didn't miss something.
Strictly speaking they just seem to enforce project build order,
right?
Regards, Raimund.
Re: Project properties -> paths and symbols [message #206224 is a reply to message #206193] Fri, 07 December 2007 06:41 Go to previous messageGo to next message
> project_root/
> |->bin/
> |->src/
> |->tools/
Yes.
>>> project.
I am sorry. I do not use the Export settings and I am not certain what
they stand for.
Axel
Re: Project properties -> paths and symbols [message #206232 is a reply to message #206216] Fri, 07 December 2007 06:44 Go to previous messageGo to next message
>>> current project.
> right?
Not quite. They enforce that referenced projects are build as well if you
build the current project. The build order is usually alphabetical. But
you can change the build order in Preferences.
Axeld
Re: Project properties -> paths and symbols [message #206255 is a reply to message #206232] Fri, 07 December 2007 12:25 Go to previous message
>>>> current project.
>> right?
> you build the current project. The build order is usually
> alphabetical. But you can change the build order in Preferences.
If you had said "built before" instead of "built as well" that
would've been what I basically understood, i.e. references determining
build order in the sense of walking up a (hopefully acyclic) directed
build dependency graph.
I assume that's what you meant anyway.
What I was wondering is whether references might create other,
"hidden" dependencies, like on the indexing. The term is just that
vague.
I take your reply as a "no", though. Implying that references are all
just about the build process.
Thanks, Raimund.
Previous Topic:Weird ToolChain in project wizard
Next Topic:simulator for arm SoC
Current Time: Fri Sep 19 09:36:40 EDT 2025
Powered by FUDForum. Page generated in 0.05636 seconds
