Home » Language IDEs » ServerTools (WTP) » Programmatically adding imports to jsp file
Programmatically adding imports to jsp file [message #205931] Mon, 17 December 2007 08:22 Go to next message
Originally posted by: Tanyu.Krasimirov.Trifonov.sap.com
Hi All,
I want to programmatically add some code to existing jsp file. First I
have to check if the required classes are already imported and if they’re
not – I have to add import statements. The problem is that I cannot find a
way how I can check if the import statement is already present – I tried
to use
IModelManager mm = StructuredModelManager.getModelManager();
IStructuredModel sm = null;
try {
sm = mm.getModelForEdit(jspFile);
} catch (IOException e) {}
catch(CoreException e){}
if (sm !=null && sm instanceof DOMModelForJSP){
DOMModelForJSP model = (DOMModelForJSP)sm;
IDOMDocument dom = model.getDocument();
if (sm != null){
sm.releaseFromEdit();
But I cannot figure out how I can get the already existing import
statements. Any help is appreciated.
Tanyu Trifonov
Re: Programmatically adding imports to jsp file [message #206000 is a reply to message #205931] Mon, 17 December 2007 19:25 Go to previous messageGo to next message
> they�re not � I have to add import statements. The problem is that I
> cannot find a way how I can check if the import statement is already
> present � I tried to use
> try {
> if (sm != null){
You'll want to use org.w3c.dom.Document.getElementsByTagName(String)
on the IDOMDocument to find the jsp:directive.page elements
representing the page directives. From there you can look at the
attributes defining the import list.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Programmatically adding imports to jsp file [message #206062 is a reply to message #206000] Thu, 20 December 2007 03:35 Go to previous message
Hi Nitin,
Thank you very much for your help.
Tanyu
>> theyᅵre not ᅵ I have to add import statements. The problem is that I
>> present ᅵ I tried to use
>> try {
>> if (sm != null){
> Nitin Dahyabhai
> IBM Rational
Previous Topic:Utility Module
Next Topic:Custom positioning of the dependency libraries when publishing EAR file to the JBoss server
Current Time: Thu Oct 16 13:19:11 EDT 2025
Powered by FUDForum. Page generated in 0.06349 seconds
