Home » Eclipse Projects » GEF » bug? ImageFigure with border and localCoordinates
bug? ImageFigure with border and localCoordinates [message #205943] Fri, 23 December 2005 05:35 Go to next message
[GEF 3.2.0 and also GEF CVS head]
I have an ImageFigure subclass which returns true from
useLocalCoordinates(). I also set a border on this ImageFigure.
When the ImageFigure repaints, the image top-left corner is rendered at
(0, 0), and so the image is overlapped by the top & left borders, and
whitespace shows between the image and the bottom & right borders.
I suspect this is a bug; I think the implementation of
ImageFigure.paintFigure() should not call:
graphics.drawImage(getImage(), x, y);
but instead:
graphics.drawImage(getImage(), x + getInsets().left, y + getInsets().top);
Does that sound correct, or am I doing something silly?
Jason.
Re: bug? ImageFigure with border and localCoordinates [message #206074 is a reply to message #205943] Fri, 23 December 2005 19:50 Go to previous messageGo to next message
For the benefit of others, I just created a new Figure that does much of
what ImageFigure already does (although I removed support for alignment),
and my paintFigure() method is shown below. Seems to work well for my
needs, which has a border and local coordinates, and with the parent
figure containing many of these children in a FlowLayout.
* Paint the image, after first translating the client area
* to the parent's coordinate system.
protected void paintFigure(Graphics graphics) {
super.paintFigure(graphics);
if (getImage() == null)
return;
Rectangle area = getClientArea();
translateToParent(area);
graphics.drawImage(getImage(), area.getTopLeft());
Re: bug? ImageFigure with border and localCoordinates [message #206226 is a reply to message #206074] Mon, 26 December 2005 23:55 Go to previous message
ImageFigure should work with a border. You've found a bug in that
getClientArea should not be called from paintFigure(). Please open a bug
report.
The fix is something like:
Rect area = getBounds().getCropped(getInsets());
"Jason Grant" <junk@logular.com> wrote in message
news:pan.2005.12.24.00.50.41.462026@logular.com...
> return;
Previous Topic:Something about ActionBarcontributor and action of movement
Next Topic:GEF shapes sample
Current Time: Fri Jul 18 21:48:11 EDT 2025
Powered by FUDForum. Page generated in 0.08602 seconds
