Home » Language IDEs » ServerTools (WTP) » edit HTML file
edit HTML file [message #205514] Sun, 09 December 2007 06:19 Go to next message
Originally posted by: nospam.noemail.com
i've just downloaded the latest version of eclipse to get use to it.
i've downloaded the WTP, PDT and SDK packages.
However, i'm not able to edit a simple HTML file which already exists.
automatically, when i double click on it, eclipse displays the result of
this html file.
none of the 4 "parametered editors" (system editor, default editor, ...)
open it (except text editor).
where is the problem ?
why can I not open it thanks standard eclipse editor (the same as i have
for js edition) ?
thx.
A.
Re: edit HTML file [message #205537 is a reply to message #205514] Sun, 09 December 2007 19:29 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Alain R. wrote:
> this html file.
> for js edition) ?
Make sure you are running Eclipse with at least a Java 1.5 runtime
environment. WTP requires 1.5 otherwise some features will be disabled.
Dave
Re: edit HTML file [message #205592 is a reply to message #205537] Tue, 11 December 2007 12:42 Go to previous messageGo to next message
I have 1.6 installed and still have this issue :-(
David Carver wrote:
> Alain R. wrote:
>> Hi,
>> of this html file.
>> ...) open it (except text editor).
>> have for js edition) ?
> Dave
Re: edit HTML file [message #205599 is a reply to message #205592] Tue, 11 December 2007 13:34 Go to previous messageGo to next message
Did you download all the pre-reqs. You can also download the PDT
All-In-One package which will make sure you have everything.
Dave
Re: edit HTML file [message #205607 is a reply to message #205599] Wed, 12 December 2007 02:00 Go to previous messageGo to next message
i've downloaded the PDT all in one package in this purpose : to be sure
that i had everything needed :-(
> Dave
Re: edit HTML file [message #205614 is a reply to message #205592] Wed, 12 December 2007 03:20 Go to previous messageGo to next message
Originally posted by: mauro.molinari.cardinis.com
You have 1.6 installed, but are you sure Eclipse is using it?
Try Help | About Eclipse Platform | Configuration details and search for
java.runtime.version property.
If it is not >1.5, try:
eclipse -vm <path to javaw.exe of JRE >1.5.x>
Hope this helps.
Mauro.
Re: edit HTML file [message #205630 is a reply to message #205607] Wed, 12 December 2007 10:42 Go to previous message
> David Carver wrote:
Try JDK 1.5, PDT has said they don't support JDK 1.6, even though it
should work,
Previous Topic:Getting JSP and JDBC example to work
Next Topic:Re-deploying tomcat 5.5
Current Time: Thu Jul 24 21:28:56 EDT 2025
Powered by FUDForum. Page generated in 0.06054 seconds
