Home » Archived » BIRT » about parameter group
about parameter group [message #20552] Fri, 18 March 2005 01:42 Go to next message
Originally posted by: eros.design.gmail.com
hi,
could someone tell me what is parameter group, is it just a parameter
'folder' or with some special function in it???
BTW, when will BIRT release help documentation?
thanks
Chan
www.chinaui.org
Re: about parameter group [message #20622 is a reply to message #20552] Fri, 18 March 2005 13:15 Go to previous messageGo to next message
Chan,
Yes, a parameter group is just a UI folder. The idea here is that some
reports provide a large number of prameters. Grouping them helps organize
the parameter entry UI. A UI could use the grouping info to, for example,
keep a "rarely-used" parameter group collapsed until the user needs those
particular parameters.
BIRT will release help documentation as part of the 1.0 release. We're still
in the community review stage, and the team is in the process of creating
the documentation.
- Paul
Paul Rogers
BIRT PMC
"eros_chan" <eros.design@gmail.com> wrote in message
news:opsntl8y0r66h8ge@chenke...
> hi,
> thanks
> Chan
> www.chinaui.org
Re: about parameter group [message #22058 is a reply to message #20622] Mon, 21 March 2005 23:45 Go to previous messageGo to next message
thanks veru much. is there any UID/UE guys need for this project?
On Fri, 18 Mar 2005 10:15:18 -0800, Paul Rogers <progers@actuate.com> =
wrote:
> Yes, a parameter group is just a UI folder. The idea here is that some=
> reports provide a large number of prameters. Grouping them helps organ=
ize
> the parameter entry UI. A UI could use the grouping info to, for examp=
le,
> keep a "rarely-used" parameter group collapsed until the user needs th=
ose
www.chinaui.org
Re: about parameter group [message #22144 is a reply to message #22058] Tue, 22 March 2005 13:30 Go to previous messageGo to next message
Can you explain "UID/UE" a bit? I'm not quite sure what these mean in this
context.
- Paul
Paul Rogers
BIRT PMC
news:opsn0vhikp66h8ge@chenke...
www.chinaui.org
Re: about parameter group [message #22186 is a reply to message #22144] Tue, 22 March 2005 21:14 Go to previous message
sorry, means user interface/graphic designer and usability engineer.
On Tue, 22 Mar 2005 10:30:05 -0800, Paul Rogers <progers@actuate.com> =
wrote:
> Can you explain "UID/UE" a bit? I'm not quite sure what these mean in =
> this
> context.
> - Paul
> Paul Rogers
> BIRT PMC
> wrote:
>> Yes, a parameter group is just a UI folder. The idea here is that som=
e
>> reports provide a large number of prameters. Grouping them helps =
>> organize
>> the parameter entry UI. A UI could use the grouping info to, for =
>> example,
>> keep a "rarely-used" parameter group collapsed until the user needs =
>> those
www.chinaui.org
Previous Topic:Error in processing Input Parameters
Next Topic:Birt Create a Pdf report can't show correct chinese word
Current Time: Tue Jul 22 07:40:24 EDT 2025
Powered by FUDForum. Page generated in 0.26236 seconds
