Home » Archived » BIRT » Birt Home
Birt Home [message #205102] Wed, 06 December 2006 11:32 Go to next message
My webapp directory is outside the normal tomcat directory. The server.xml
has been modified for the new location and other web apps seem to be working
fine. However, Birt cannot find the viewer images and some other things.
Do I need to create an environmental variable for Birt_home to resolve this
problem?? I wouldn't think that would be necessary but something needs to
change. I wouldn't think that I need to set the web.xml in Birt since all
the sub folders are still in the same relative path.
Any help would be appreciated.
Bill
Re: Birt Home [message #205151 is a reply to message #205102] Wed, 06 December 2006 12:52 Go to previous message
If you are using the BIRT 2.1.1 Web Viewer, it looks for a platform
directory below WEB-INF. This is not configurable without a change to the
Viewer code.
If you are building your own app this can be changed.
Jason
"bdecamp" <bdecamp@b2dsolutions.com> wrote in message
news:el6raj$7af$1@utils.eclipse.org...
> server.xml has been modified for the new location and other web apps seem
> to be working fine. However, Birt cannot find the viewer images and some
> other things. Do I need to create an environmental variable for Birt_home
> to resolve this problem?? I wouldn't think that would be necessary but
> something needs to change. I wouldn't think that I need to set the
> web.xml in Birt since all the sub folders are still in the same relative
> path.
> Bill
Previous Topic:Storing reports off of the filesystem
Next Topic:Dynamically changing chart size in the Birt Report Designer
Current Time: Fri Nov 07 17:12:10 EST 2025
Powered by FUDForum. Page generated in 0.12690 seconds
