Trinidad components do not render in Visual Editor [message #205104] |
Thu, 29 November 2007 09:26  |
Originally posted by: bart.kummel.koopmanint.com
Hi List,
When I'm designing a JSF JSP with the visual editor, I only see empty
boxes in both the design view and the preview when I use components from
the Trinidad (1.2.3) component library. When I use the standard components
from the Sun RI instead, those components do render as one would expect.
Is there a way to get the Trinidad components rendered in the visual
editor?
Bart Kummel
Re: Trinidad components do not render in Visual Editor [message #933958 is a reply to message #205121] |
Fri, 05 October 2012 09:52  |
Are you aware if such Design-Time Tag Metadata exists already anywhere
for Trinidad Components Library?
Thanks in advance,
Chemi.
On 11/29/2007 9:35 PM, Ian Trimble wrote:
> The current mechanism is to provide "Design-Time Tag Metadata".
> Open Help, and then take a look at the following items:
> * JavaServer Faces Tooling Developer Guide
> * Programmer's Guide
> * Design-Time Tag Metadata Operations
> and
> * Tutorials
> * Providing Design-Time Tag Metadata
> The standard libraries work out-of-the-box because we have provided this
> metadata for them.
> We are currently looking at new ways of providing design-time visual
> representations that may require little or no metadata - this is a lofty
> goal, though, since there will likely always be a need for at least some
> metadata to be provided.
FUDForum. Page generated in 0.25895 seconds
