Home » Eclipse Projects » GEF » back to default 'Select' tool after creating a connection
back to default 'Select' tool after creating a connection [message #204012] Tue, 29 November 2005 13:04 Go to next message
Originally posted by: pbeagan.yahoo_dontspamme_.com
Hi, In my editor, a user can create a connection between to objects. When
the second node of the connection is clicked, the connection is created.
At this point GEF still has the Connection tool selected for the user to
create another connection. What do I need to do to make it so the user has
the 'Select' tool after a connection is created? Thanks.
Re: back to default 'Select' tool after creating a connection [message #204292 is a reply to message #204012] Thu, 01 December 2005 14:36 Go to previous messageGo to next message
toolEntry.setToolProperty(AbstractTool.PROPERTY_UNLOAD_WHEN_ FINISHED,
BOOLEAN.TRUE);
"Patrick" <pbeagan@yahoo_dontspamme_.com> wrote in message
news:dmi4iu$k58$1@news.eclipse.org...
> When
> has
Re: back to default 'Select' tool after creating a connection [message #204755 is a reply to message #204292] Tue, 06 December 2005 09:19 Go to previous messageGo to next message
Thanks - I just wanted to post the same question!
And I have a related question:
I dislike the behaviour, that I have to first click (and release) on the
first object and then click again on the second one.
In most other drawing applications I have used so far, one creates a
connection by pressing the mouse over the first object and then - while
keeping the mouse-button pressed - moves the mouse over to the second
object and releases the button there, i.e. press mouse button over obj1
=> move (or drag) to obj2 => release mouse button over obj2.
Can that behavior be achieved with a similarly simple modification or
would that require some major code changes?
Michael
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dmnjbk$9mg$1@news.eclipse.org...
> BOOLEAN.TRUE);
>> When
>> created.
>> to
>> user has
Re: back to default 'Select' tool after creating a connection [message #204761 is a reply to message #204755] Tue, 06 December 2005 14:53 Go to previous messageGo to next message
You bet. Use the ConnectionDragCreationTool as your tool. Call
ToolEntry#setToolClass with that class.
"Michael Moser" <mmo@zurich.ibm.com> wrote in message
news:dn46kn$93r$1@news.eclipse.org...
> object and releases the button there, i.e. press mouse button over obj1 =>
> Michael
>> BOOLEAN.TRUE);
>>> When
>>> has
Re: back to default 'Select' tool after creating a connection [message #204769 is a reply to message #204761] Tue, 06 December 2005 16:16 Go to previous messageGo to next message
news:dn4q7m$a8g$1@news.eclipse.org...
Wow, that was easy!
I added the line marked <<< to the existing code:
// Add (solid-line) connection tool
toolEntry =
new ConnectionCreationToolEntry("Solid connection", ...);
toolEntry.setToolClass(ConnectionDragCreationTool.class); // <<<
added this line
toolGroup.add(toolEntry);
But now I get a somewhat odd behaviour, that I can't explain:
When I now draw a connection it at first behaves as desired, i.e. it
draws the connection after releasing the mouse over the second object.
But after that, the mouse-icon for connections (the "plug") remains but
it's now combined with a no-entry sign no matter where I move it on the
canvas. That mouse-cursor only goes away, when the mouse leaves the
drawing canvas (and does not come back - when one re-enters it). So -
apparently, after having temporarily left the canvas the tool is
deselected - at least one can NOT create another connection with it -
but on the palette it's still marked as selected.
Isthis working as designed or is this a bug or did I miss something
here???
Michael
Re: back to default 'Select' tool after creating a connection [message #204832 is a reply to message #204769] Wed, 07 December 2005 22:39 Go to previous messageGo to next message
> When I now draw a connection it at first behaves as desired, i.e. it draws
> deselected - at least one can NOT create another connection with it - but
Perhaps the tool is staying active? Can you create a second connection? Try
setting the property "unload when finished" to true using similar technique.
Otherwise, it could be a bug like a lingering mouse cursor or something.
> here???
> Michael
Re: back to default 'Select' tool after creating a connection [message #204848 is a reply to message #204832] Thu, 08 December 2005 04:14 Go to previous messageGo to next message
Hi again!
news:dn89ta$btf$1@news.eclipse.org...
> connection? Try setting the property "unload when finished" to true
> using similar technique. Otherwise, it could be a bug like a lingering
It's a strange combination:
The tool is NOT staying active - regardless of whether I add the "unload
when finished" property or not.
But the "plug"-cursor always stays, also regardless of whether "unload
when finished" is there or not. Until one leaves the drawing area by
when the cursor disappears.
I also tested/verified this by adding the line
tool.setToolClass(ConnectionDragCreationTool.class);
to the GEF example "Shapes" (class: ShapesEditorPaletteFactory, method:
createToolsGroup):
tool = new ConnectionCreationToolEntry("Solid connection",
"Create a solid-line
connection",
new CreationFactory()
public Object getNewObject() {
return null;
// see
// ShapeEditPart#createEditPolicies()
// this is abused to
// transmit the desired line
// style
public Object getObjectType() {
return Connection.SOLID_CONNECTION;
ImageDescriptor.createFromFile(ShapesPlugin.class,
"icons/connection_s16.gif"),
"icons/connection_s24.gif"));
// added by MMO:
tool.setToolClass(ConnectionDragCreationTool.class); // <<<<<
// the odd behaviour stays with and without this:
// tool.setToolProperty(AbstractTool.PROPERTY_UNLOAD_WHEN_FINIS HED,
Boolean.TRUE);
toolGroup.add(tool);
Summarizing: I'ld say this is a bug! Can you reproduce this? If so I'll
enter it in bugzilla...
Michael
Re: back to default 'Select' tool after creating a connection [message #204944 is a reply to message #204848] Thu, 08 December 2005 17:02 Go to previous messageGo to next message
Go ahead and open it so you'll be CC'ed on the bugzilla.
> when finished" is there or not. Until one leaves the drawing area by when
> createToolsGroup):
> "Create a solid-line connection",
> return null;
> // see
> // style
> // added by MMO:
> Boolean.TRUE);
> Michael
Re: back to default 'Select' tool after creating a connection [message #204969 is a reply to message #204944] Fri, 09 December 2005 04:16 Go to previous message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=120077
news:dnaago$7r8$1@news.eclipse.org...
Previous Topic:SWTGraphics no longer draws on SWT Canvas in 3.1
Next Topic:EMF and GEF: an interesting but strange result...
Current Time: Tue Sep 16 17:29:47 EDT 2025
Powered by FUDForum. Page generated in 0.09956 seconds
