| 3.1 support [message #17530] |
Thu, 10 March 2005 13:32  |
When will BIRT support Eclipse 3.1? Running the first preview build, there
are a few errors.
-Chris
| Re: 3.1 support [message #20628 is a reply to message #20463] |
Sat, 19 March 2005 00:35  |
The development team plans to support Eclipse 3.1 within 30 days after the
final 3.1 release. However, if the community can identify specific problems
before then, the development team will try to fix them as part of the BIRT
release 1.0 work. Please file any problems you find in Bugzilla.
- Paul
Paul Rogers
BIRT PMC
"Chris" <schtoo@schtoo.com> wrote in message
news:d1cm5j$cqq$1@www.eclipse.org...
> We're in the exact same situation. We're developing an RCP app on 3.1.
> BIRT only supporting 3.0 (even to start) doesn't bode well :(
> -Chris
> "ekkehard" <ekkehardREMOVE_NO_SPAM@gentz-software.de> wrote in message
> news:d1cbbd$dva$1@www.eclipse.org...
>> hi scott,
>> because we're building a RCP we really need the things from 3.1M5a+
>> so we have decided to make all our development using 3.1 milestones.
>> if BIRT doesn't run under actual Milestones then we cannot make tests :-(
>> regards
>> ekkehard
>> Scott Rosenbaum schrieb:
>>> Ekkehard,
>>> Good to hear from you. Hope the project is going well. I should have
>>> been a little more precise in my description of BIRT and 3.1.
>>> I was using 3.1.0 M1. While at the conference, I witnessed someone
>>> working with 3.1 M5a and saw that they were having some fairly
>>> significant issues with the rendering in some of the dialogs. I am in
>>> the process of setting up an additional system that I will use to run
>>> 3.1 M5++ but I don't think that BIRT is quite ready to run there.
>>> As far as I know, the BIRT developers primary goal is to have a stable
>>> release for 3.0.1 available by May 1. I don't think there will be any
>>> work on compatibility with 3.1 until Release 1 is complete.
>>> Scott Rosenbaum
>>> BIRT PMC
>>> ekkehard wrote:
>>>> hi scott,
>>>> good to hear that birt runs with 3.1M5a.
>>>> I'll start heavy testing BIRT in 2-3 weeks,
>>>> then you'll hear more from me and the proposed scenarios ;-)
>>>> (I don't forgot out talk at eclipseCon)
>>>> regards
>>>> ekkehard
>>>> erpOS ERP Open Source Software
>>>>> Which version of 3.1 are you running?
>>>>> I have been working with 3.1.0 Build id: 200408122000 and have not had
>>>>> any
>>>>> significant problems.
>>>>> Scott Rosenbaum
>>>>> BIRT PMC
>>>>> news:d0q3th$t84$1@www.eclipse.org...
>>>>> there
>>>>>> are a few errors.
>>>>>> -Chris
FUDForum. Page generated in 0.05284 seconds
