Home » Eclipse Projects » GEF » about selection action
about selection action [message #203918] Tue, 29 November 2005 04:11 Go to next message
Originally posted by: XXX.cn.ibm.com
Hi, pals
what should i do if I want my selection actions to correctly update the
status(enable/disable) when
the selection changes. For example, at the begining, i selected node one,
and at the same time, action A
enabled. while in the GEF editor, i keep selecting node one, after serveral
second, the attribute of node one
updated by underlined something, and action A should be disable.
thx a lot.
Re: about selection action [message #203941 is a reply to message #203918] Tue, 29 November 2005 05:32 Go to previous messageGo to next message
Sounds like you need to hook a listener that listens to you model for
such changes and updates all selection actions if a property changed and
the element is currently selected.
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: about selection action [message #203966 is a reply to message #203918] Tue, 29 November 2005 08:55 Go to previous messageGo to next message
Originally posted by: none.unknown.com
Look at LogicEditor#createActions(). Make sure you register your actions as
selection actions, and their update() method will be invoked whenever the
selection changes.
"Magic" <XXX@cn.ibm.com> wrote in message
news:dmh606$d0$1@news.eclipse.org...
> Hi, pals
serveral
> thx a lot.
Re: about selection action [message #204059 is a reply to message #203941] Wed, 30 November 2005 00:47 Go to previous messageGo to next message
Yes, maybe we have to do it in this way. :(
and w'r used to hope there will be a better way in GEF.
anyway, thx a lot.
"Gunnar Wagenknecht" <gunnar@wagenknecht.org>
??????:dmhao5$77v$2@news.eclipse.org...
>> serveral
> Cu, Gunnar
> Gunnar Wagenknecht
Re: about selection action [message #204073 is a reply to message #204059] Wed, 30 November 2005 04:07 Go to previous messageGo to next message
> anyway, thx a lot.
Mhm. I don't understand your problem. There is a change in your
underlying model. GEF can't know about this change until you tell GEF to
refresh. Same goes for the actions.
Cu, Gunnar
Gunnar Wagenknecht
Re: about selection action [message #204204 is a reply to message #203966] Wed, 30 November 2005 23:07 Go to previous messageGo to next message
Hi, Pratik
After go through the code of selectionAction, we found when the undergroud
model is changed, we could invoke refresh() method to get the status to
update.:)
"Pratik Shah" <none@unknown.com> д
Re: about selection action [message #204303 is a reply to message #204059] Thu, 01 December 2005 14:37 Go to previous message
You should hook the action to the command stack. Whenever a command is
executed, undone, etc., refresh the action's enablement. And also keep it as
a selection listener too.
news:dmjedi$8ff$1@news.eclipse.org...
> anyway, thx a lot.
>>> one,
>>> serveral
>> Cu, Gunnar
>> Gunnar Wagenknecht
Previous Topic:contentassist-like Popup menu
Next Topic:any suggestion for an 'ExpandAnimatedFigure'
Current Time: Sat Nov 08 16:29:42 EST 2025
Powered by FUDForum. Page generated in 0.04432 seconds
