Home » Language IDEs » ServerTools (WTP) » Custom positioning of the dependency libraries when publishing EAR file to the JBoss server
Custom positioning of the dependency libraries when publishing EAR file to the JBoss server [message #203892] Wed, 07 November 2007 07:49 Go to next message
Originally posted by: list.inksystems.net
Hi all,
is there any way to explicitly specify where module dependency jars will
be stored in the resulting .ear file when project is published to the
server?
The problem i have is that there couple of jar files that should be
available (i.e. shared) to all modules in the ear file. The target
platform is Jboss which means that they have to be in lib directory
inside the .ear file. Application is 1.3 compliant hence there is no way
to use J2EE 5 methods of customizing location of the EAR libraries. But
when WTP publishing project (for internal run or debuging) to JBoss all
files appear in the root of the .ear file which makes them unavailable
to the EAR deployer classloader.
So, the question (as above) is can i explicitly specify where publisher
should put the jar files? I am digging into this problem for past couple
of weeks and seems like there is no easy way of doing this.
In case i am right and there is no easy way of doing this is there any
possible workaround for this. I can use ant build in order to do this
deployment to the externally configured server but it is confusing for
some developers in the team so it would be nice to have the easier
solution from the user's perspective.
Anyway, any help will be greatly appreciated.
Thanks in advance,
Igor.
Re: Custom positioning of the dependency libraries when publishing EAR file to the JBoss server [message #206022 is a reply to message #203892] Tue, 18 December 2007 11:50 Go to previous messageGo to next message
Answering to myself... May be it will be useful for the others.
Quite short patch would allow to hardcode /lib directory inside of the
..ear file as destination to the dependency libraries application is
being published by eclipse:
Index:
org.eclipse.jst.j2ee/j2eeplugin/org/eclipse/jst/j2ee/interna l/deployables/J2EEFlexProjDeployable.java
RCS file:
/cvsroot/webtools/jeetools/plugins/org.eclipse.jst.j2ee/j2ee plugin/org/eclipse/jst/j2ee/internal/deployables/J2EEFlexPro jDeployable.java,v
retrieving revision 1.68.2.1
diff -r1.68.2.1 J2EEFlexProjDeployable.java
146c146
< if (J2EEProjectUtilities.isEARProject(component.getProject()))
> if (J2EEProjectUtilities.isEARProject(component.getProject())) {
148c148
< else
> } else {
149a150
241c242
< addUtilMembers(component);
> addUtilMembers(component,
J2EEProjectUtilities.isDynamicWebProject(component.getProjec t()));
574c575
< addUtilMembers(consumedComponent);
> addUtilMembers(consumedComponent,
695c696,701
< cpRefRuntimePath = runtimePath;
> // JBoss should publish dependant libraries int lib directory
of the .ear file
> if (web) {
> } else {
> cpRefRuntimePath = runtimePath.append("lib/");
Index:
org.eclipse.jst.server.generic.core/src/org/eclipse/jst/serv er/generic/core/internal/publishers/EarModuleAssembler.java
RCS file:
/cvsroot/webtools/servertools/plugins/org.eclipse.jst.server .generic.core/src/org/eclipse/jst/server/generic/core/intern al/publishers/EarModuleAssembler.java,v
retrieving revision 1.7
diff -r1.7 EarModuleAssembler.java
95a96,97
> } else if(module.getModuleType().getId().equals("jst.utility")) {
> super.packModule(module, deploymentUnitName,
destination.append("lib/"));
Index:
org.eclipse.wst.web/static_web_project/org/eclipse/wst/web/i nternal/deployables/ComponentDeployable.java
RCS file:
/cvsroot/webtools/jeetools/plugins/org.eclipse.wst.web/stati c_web_project/org/eclipse/wst/web/internal/deployables/Compo nentDeployable.java,v
retrieving revision 1.20
diff -r1.20 ComponentDeployable.java
323c323
< public IModuleResource[] members() throws CoreException {
> public IModuleResource[] members(boolean web) throws CoreException {
333c333
< addUtilMembers(vc);
> addUtilMembers(vc, web);
345c345
< protected void addUtilMembers(IVirtualComponent vc) {
> protected void addUtilMembers(IVirtualComponent vc, boolean web) {
354c354,358
< addUtilMember(vc, reference, reference.getRuntimePath());
> if (web) {
> } else {
reference.getRuntimePath().append("/lib"));
Igor.
Igor Kolomiyets пишет:
> Hi all,
> server?
> Thanks in advance,
> Igor.
Re: Custom positioning of the dependency libraries when publishing EAR file to the JBoss server [message #206076 is a reply to message #206022] Thu, 20 December 2007 12:59 Go to previous message
The patch would be better placed on a bug. I would recommend opening an
issue in bugzilla, for this with the patch attached to it. Otherwise,
it will get lost here.
http://bugs.eclipse.org/bugs
Dave
Previous Topic:Programmatically adding imports to jsp file
Next Topic:Error in Eclipse jsp file
Current Time: Sun Jul 27 02:12:44 EDT 2025
Powered by FUDForum. Page generated in 0.24376 seconds
