Home » Eclipse Projects » GEF » SWTGraphics - wrong behaviour
SWTGraphics - wrong behaviour [message #203718] Fri, 25 November 2005 05:00 Go to next message
Originally posted by: kiril.mitov.disy-bg.com
Hi all,
I just want to make sure that the folowing behaviour is not a bug. If it
is I will commit it.
The problem is that the result of the following pieces of code is
different:
Code1:
graphics.pushState();
graphics.translate(10,10);
graphics.rotate(0);//!!! rotate by 0 degrees.
graphics.drawRectangle(0,0,100,100);
graphics.popState();
Code2:
//!!!here the rotate method is commented so there
is no rotation
// graphics.rotate(0);
When the following methods are executed the result is different.
In the first - Code1 the rectangle is drawn on location 20,20
On the seconde - Code2 the rectangle is drawn on location 10,10
Should the location be different when a rotate(0) method is called.
I am using GEF_3.1.1
With eclipse3.2 M3
I am working on a Linux machine with GTK 2.8.2
Thaks.
Re: SWTGraphics - wrong behaviour [message #203753 is a reply to message #203718] Sat, 26 November 2005 23:06 Go to previous messageGo to next message
SWT has fixed this bug in the latest integration builds.
"kiril mitov" <kiril.mitov@disy-bg.com> wrote in message
news:b885ce36a07ad400b05c95575bf0fcdf$1@www.eclipse.org...
> Hi all,
> different:
> Code1:
> Code2:
> is no rotation
> With eclipse3.2 M3
> Thanks
> Thaks.
Re: SWTGraphics - wrong behaviour [message #203842 is a reply to message #203753] Mon, 28 November 2005 11:05 Go to previous message
Yes I saw it.
Thanks...
Previous Topic:PDF export
Next Topic:how to move an anchor by user
Current Time: Fri Nov 07 23:30:23 EST 2025
Powered by FUDForum. Page generated in 0.03927 seconds
