Home » Archived » BIRT » SQL Error with jndi connection but not birt created connection
SQL Error with jndi connection but not birt created connection [message #203776] Wed, 29 November 2006 13:19 Go to next message
--------------010206080100080604090105
Content-Type: text/plain; charset=us-ascii; format=flowed
I am using a fairly complex sql (see end) that works just fine with a birt created connection in
both the report designer and the webserver (Similar integration as Servlet Example). When I instead
change to a jndi supplied connection (or the pass through connection example from Jason), I get
errors. The success and fail logs are attached. It looks to me like the metadata that is being
returned is different in each case.
Does anyone have any clue what is going on here?
jboss datasource definition:
<datasources>
<no-tx-datasource>
<jndi-name>env/ReportDS</jndi-name>
<connection-url>jdbc:jtds:sybase://tca-db01:5000/Risk;tds=5.0;lastupdatecount=true</connection-url>
<driver-class>net.sourceforge.jtds.jdbc.Driver</driver-class >
<user-name>XXXX</user-name>
<password>XXXX</password>
<min-pool-size>15</min-pool-size>
<max-pool-size>30</max-pool-size>
<idle-timeout-minutes>30</idle-timeout-minutes>
<blocking-timeout-millis>5000</blocking-timeout-millis>
<check-valid-connection-sql>select count(*) from sysusers</check-valid-connection-sql>
</no-tx-datasource>
</datasource>
SQL statement:
DECLARE @id_result NUMERIC(10,0)
select @id_result = ?
create table #BUCKETS (
label char(10) not null,
minVal float(16) not null,
maxVal float(16) not null
INSERT IGNORE INTO #BUCKETS VALUES('< 10', 0, .10)
INSERT IGNORE INTO #BUCKETS VALUES('10 - 25',.10,.25)
INSERT IGNORE INTO #BUCKETS VALUES('25 - 50',.25,.50)
INSERT IGNORE INTO #BUCKETS VALUES('50 - 100',.50,1.00)
INSERT IGNORE INTO #BUCKETS VALUES('> 100',1.00,1E9)
create table #R_SUMMARY (
MDVRangeOrder float not null,
Side varchar(20) not null,
TotalNames int not null,
TotalValuePerc float(16) null,
TotalShares float(16) null,
AvgShares float(16) null,
AvgMDVPerc float(16) null,
AvgMktCap float(16) null,
AvgPrice float(16) null,
AvgSpread float(16) null,
AvgCost float(16) null,
AvgCostPS float(16) null,
AvgCostPSBp float(16) null
INSERT IGNORE INTO #R_SUMMARY
SELECT B.minVal as MDVRangeOrder, A.fl_buy_sell as Side,
count(*) as TotalNames,
sum(n_trade_value_percent) as TotalValuePerc,
sum(n_shares)/1000.0 as TotalShares,
sum(n_shares)/count(*)/1000.0 as AvgShares,
sum(n_volume_percent * n_shares)/sum(n_shares) as AvgMDVPerc,
sum(n_market_cap * n_shares)/sum(n_shares)/1E9 as AvgMktCap,
sum(n_close_price * n_shares)/sum(n_shares) as AvgPrice,
sum(n_spread * n_shares)/sum(n_shares) as AvgSpread,
sum(n_cost_total * n_shares)/sum(n_shares)/1000.0 as AvgCost,
sum(n_cost_per_share * n_shares)/sum(n_shares) as AvgCostPS,
sum(n_cost_per_share_bp * n_shares)/sum(n_shares) as AvgCostPSBp
FROM R_ITGRISK_RESULTS A, #BUCKETS B
WHERE id_result = @id_result and A.n_volume_percent >= B.minVal and A.n_volume_percent < B.maxVal
GROUP BY B.minVal, A.fl_buy_sell
SELECT B.minVal as MDVRangeOrder, 'Total' as Side,
GROUP BY B.minVal
select B.minVal as MDVRangeOrder, B.label as MDVRange, A.code_summary_type as Side, C.TotalNames,
C.TotalValuePerc, C.TotalShares,
C.AvgShares, C.AvgMDVPerc, C.AvgMktCap, C.AvgPrice, C.AvgSpread,
C.AvgCost, C.AvgCostPS, C.AvgCostPSBp
from R_ITGRISK_SUMMARY A
JOIN #BUCKETS B on 1=1
LEFT OUTER JOIN #R_SUMMARY C on (A.code_summary_type = C.Side AND B.minVal = C.MDVRangeOrder)
WHERE A.id_result = @id_result
ORDER BY B.MDVRangeOrder, A.code_summary_type
DROP TABLE #BUCKETS
DROP TABLE #R_SUMMARY
name="success.log"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: inline;
filename="success.log"
Nov 29, 2006 9:35:45 AM org.eclipse.birt.report.engine.api.impl.ReportEng=
ine openReportDesign
FINE: ReportEngine.openReportDesign: name=3DTradelistMDVRange.rptdesign, =
designStream=3Djava.io.ByteArrayInputStream@618533=20
Nov 29, 2006 9:35:45 AM org.eclipse.birt.report.model.metadata.ChoiceProp=
ertyType validateXml
FINE: return internal name for choice eq
FINE: return internal name for choice asc
FINE: return internal name for choice DataSet
FINE: return internal name for choice hide
FINE: return internal name for choice any
FINE: return internal name for choice if-realized
FINE: return internal name for choice auto
FINE: return internal name for choice hyperlink
FINE: return internal name for choice inner
Nov 29, 2006 9:35:46 AM org.eclipse.birt.report.model.metadata.ChoiceProp=
FINE: return internal name for choice NoChange
FINE: return internal name for choice string
FINE: return internal name for choice static
FINE: return internal name for choice single
FINE: return internal name for choice normal
FINE: return internal name for choice none
FINE: return internal name for choice scroll
Nov 29, 2006 9:35:46 AM org.eclipse.birt.report.model.metadata.DimensionP=
ropertyType validateXml
FINE: return dimension value with user defined unit 0%
FINE: return internal name for choice repeat
FINE: return internal name for choice left
FINE: return dimension value with user defined unit 0em
FINE: return internal name for choice block
FINE: return dimension value with user defined unit 0pt
FINE: return dimension value with user defined unit 1in
FINE: return dimension value with user defined unit 1.25in
FINE: return dimension value with user defined unit 0.5pt
FINE: return internal name for choice size-to-image
FINE: return internal name for choice horizontal
Nov 29, 2006 9:35:46 AM org.eclipse.birt.report.model.metadata.ElementRef=
PropertyType validateValue
FINE: Validate the value of the element reference property as a string: I=
TGLogic.printTheme
Nov 29, 2006 9:35:47 AM org.eclipse.birt.report.model.metadata.ChoiceProp=
Nov 29, 2006 9:35:47 AM org.eclipse.birt.report.model.metadata.ElementRef=
FINE: Validate the value of the element reference property as a string: p=
rintTheme
FINE: return internal name for choice decimal
FINE: return internal name for choice text-box
FINE: return internal name for choice float
FINE: Validate the value of the element reference property as a string: R=
isk Db
FINE: return internal name for choice integer
isk Db
isk Db
isk Db
Nov 29, 2006 9:35:47 AM org.eclipse.birt.report.model.metadata.ColorPrope=
rtyType validateXml
FINE: The validated color property value 16777215
Nov 29, 2006 9:35:47 AM org.eclipse.birt.report.model.metadata.DimensionP=
FINE: return dimension value with user defined unit 11px
rtyType validateXml
FINE: The validated color property value 0
rtyType validateXml
FINE: The validated color property value 13158600
FINE: return internal name for choice solid
FINE: return dimension value with user defined unit 1px
rtyType validateXml
FINE: return dimension value with user defined unit 10px
FINE: return internal name for choice bold
rtyType validateXml
FINE: return dimension value with user defined unit 2px
rtyType validateXml
FINE: The validated color property value 16119285
rtyType validateXml
rtyType validateXml
rtyType validateXml
FINE: return internal name for choice right
rtyType validateXml
rtyType validateXml
FINE: return internal name for choice nowrap
rtyType validateXml
FINE: The validated color property value 7310750
ropertyTyp
Re: SQL Error with jndi connection but not birt created connection [message #203820 is a reply to message #203776] Wed, 29 November 2006 15:40 Go to previous messageGo to next message
Update: If I provided a connection from a manually created apache dbcp pool it worked properly. It
appears to be an integration issue between birt and the jboss pooling mechanism.
> birt created connection in both the report designer and the webserver
> (Similar integration as Servlet Example). When I instead change to a
> Jason), I get errors. The success and fail logs are attached. It looks
> to me like the metadata that is being returned is different in each case.
> <datasources>
> <no-tx-datasource>
> </no-tx-datasource>
> </datasource>
> SQL statement:
> GROUP BY B.minVal
> A.code_summary_type as Side, C.TotalNames, C.TotalValuePerc, C.TotalShares,
> DROP TABLE #BUCKETS
Re: SQL Error with jndi connection but not birt created connection [message #203885 is a reply to message #203820] Wed, 29 November 2006 20:59 Go to previous message
Ryan,
Can you log a bug entry on this?
Jason
"Ryan Barker" <barker@itgssi.com> wrote in message
news:ekkr82$27d$1@utils.eclipse.org...
> pool it worked properly. It appears to be an integration issue between
>> (Similar integration as Servlet Example). When I instead change to a jndi
>> I get errors. The success and fail logs are attached. It looks to me
>> <datasources>
>> <no-tx-datasource>
>> </no-tx-datasource>
>> </datasource>
>> SQL statement:
>> GROUP BY B.minVal
>> C.TotalShares,
>> DROP TABLE #BUCKETS
Previous Topic:Birt 2.2M2 Pdf problem
Next Topic:Strange if-else question
Current Time: Tue Nov 04 21:24:37 EST 2025
Powered by FUDForum. Page generated in 0.04039 seconds
