Home » Eclipse Projects » GEF » Compound create command
Compound create command [message #203522] Tue, 22 November 2005 12:46 Go to next message
Originally posted by: og67_sanspouriel.laposte.net
I want to create a coumpound command to create a few nodes in
my model after a drag and drop (just imagine dragging a directory) :
- one parent (a container)
- some children
1st solution,
I create all the command by hand (it works, but the
createAddCommand code is duplicated in the drop listener)
2nd solution,
I create a request for the parent
I use the target editpolicy.createAddCommand(request)
to get the command
and then, I cannot use the getCreateCommand() to get the children
commands because I don't have my parent editpart (and policies) at
this momment.
In other term, how do I create a add command with hierarchy ?
OG
Re: Compound create command [message #203555 is a reply to message #203522] Tue, 22 November 2005 14:23 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
haugh wrote:
> - some children
> 1st solution,
> 2nd solution,
> to get the command
> this momment.
> Regards
> OG
All you need to create is the topmost component, and ensure all the new
children are properly added to it. I don't see what role existing
children would play in this creation!?
CL
Re: Compound create command [message #203610 is a reply to message #203555] Wed, 23 November 2005 04:20 Go to previous message
You're right,
I thought it was more complex
OG
Previous Topic:doubts about gef
Next Topic:Rotating problem
Current Time: Sat Jul 19 02:48:39 EDT 2025
Powered by FUDForum. Page generated in 0.03419 seconds
