Home » Language IDEs » ServerTools (WTP) » new proj wizard
new proj wizard [message #203504] Fri, 02 November 2007 13:49 Go to next message
I want to write my own custom new proj wizard. The wizard will ask a
minimal set of questions - I want the output to be a "Dynamic Web
Project" plus a few artifact I manually add.
What is the right way to create a project from my wizard and set it up
appropriately as a dynamic web project?
Re: new proj wizard [message #203512 is a reply to message #203504] Fri, 02 November 2007 14:06 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Rather than building a completely new wizard, you may want to consider
creating a project facet that would add your artifacts to the project.
There is a tutorial on making new project facets that you can follow...
http://www.eclipse.org/articles/Article-BuildingProjectFacet s/tutorial.html
- Konstantin
Re: new proj wizard [message #203519 is a reply to message #203512] Fri, 02 November 2007 14:15 Go to previous messageGo to next message
Thanks for the tutorial link - need to read it, but my idea is to
simplify the existing wizard. I dan't want to confuse my users with all
the normal wizard questions. For example - I know the targeted runtime
ahead of time so I don't want the user to have to answer that question.
> - Konstantin
Re: new proj wizard [message #203526 is a reply to message #203519] Fri, 02 November 2007 14:41 Go to previous messageGo to next message
Ok. The api that you want is available in the following package:
org.eclipse.wst.common.project.facet.core.*
A dynamic web project is basically a project with at least "jst.java"
and "jst.web" facets installed.
The following class is an entry point to the API with a bunch of static
methods:
org.eclipse.wst.common.project.facet.core.ProjectFacetsManag er
You will want to call one of the create methods on ProjectFacetsManager
to get an IFacetedProject object. That object has methods for setting
the runtime, installing facets, etc.
- Konstantin
Re: new proj wizard [message #203540 is a reply to message #203526] Fri, 02 November 2007 15:23 Go to previous messageGo to next message
Thanks again - without the newsgroup - where is the best place to go to
find out about api's like this?
> methods:
> - Konstantin
Re: new proj wizard [message #203548 is a reply to message #203540] Fri, 02 November 2007 15:32 Go to previous messageGo to next message
If you get the sdk version of WTP from the download site, it contains
the source code as well as documentation for extenders. This includes
documentation about the extension points as well javadoc. Of course, the
trouble with looking at javadoc for something as large as WTP, is that
you kinda have to know which way to look first. :)
- Konstantin
Re: new proj wizard [message #203556 is a reply to message #203548] Fri, 02 November 2007 16:04 Go to previous messageGo to next message
Gotcha - hopefully one last thing - I am creating the project - but how
do I set the "Default Server" used by Run on Server - so that the
project is readly to deploy in the servers view right after creation?
Right now - I don't see a Server entry at all in the project properties.
> - Konstantin
Re: new proj wizard [message #203563 is a reply to message #203556] Fri, 02 November 2007 16:17 Go to previous messageGo to next message
Nevermind - this seems to work:
IFacetedProject fp = ProjectFacetsManager.create(proj, true, monitor);
fp.installProjectFacet(ProjectFacetsManager.getProjectFacet( "jst.java")
.getDefaultVersion(), null, monitor);
fp.installProjectFacet(ProjectFacetsManager.getProjectFacet( "jst.web")
>> the trouble with looking at javadoc for something as large as WTP, is
>> that you kinda have to know which way to look first. :)
>> - Konstantin
Re: new proj wizard [message #203570 is a reply to message #203556] Fri, 02 November 2007 16:19 Go to previous messageGo to next message
You need to definite a server runtime. You can do that using api located
in this package:
org.eclipse.wst.server.core
The starting class for that api is called ServerCore.
Once you have create the runtime, you will be able to see it in the
Targeted Runtimes properties page of your project, but it will not be
selected, you can go back to the faceted project api.
Use the following method to find the runtime. Note that this IRuntime is
different than server.core's IRuntime.
org.eclipse.wst.common.project.facet.core.runtime.RuntimeMan ager.getRuntime(
<name>)
Then you will want to call
IFacetedProject.setTargetedRuntimes(List<IRuntime>) on your project.
- Konstantin
Re: new proj wizard [message #203822 is a reply to message #203570] Tue, 06 November 2007 16:19 Go to previous messageGo to next message
I can see in ServerCore where I can query the installed servers and
runtimes but how would I add a new runtime or server?
> in this package:
> <name>)
> - Konstantin
Re: new proj wizard [message #203829 is a reply to message #203822] Tue, 06 November 2007 16:29 Go to previous messageGo to next message
found this from Konstantin online (I'll try it out):
The API that you need is in org.eclipse.wst.server.core. You first need
to retrieve the IRuntimeType object that corresponds to the tomcat
runtime of the appropriate version. You can do that using the ServerCore
class. Once you have the IRuntimeType object, it has a factory method
for creating an IRuntimeWorkingCopy. You create the working copy, fill
it out and use the save method to persist your changes. That adds the
runtime to the workspace. Also, make sure to call validate prior to
calling save to make sure that you are not saving a mis-configured runtime.
Re: new proj wizard [message #203915 is a reply to message #203829] Wed, 07 November 2007 11:55 Go to previous messageGo to next message
I am having trouble setting the install dir of my server runtime. I use
setLocation() on the server runtime working copy but the result in the
debugger shows this on the RuntimeWorkingCopy instance map member (which
I can't access directly because it is discouraged):
{generic_server_instance_properties={serverRootDirectory=/yo ur_server_root/appservers/jboss-4.0.3},
id-set=true, location=D:/PROGRA~1/NORTEL~1/SCE/Jboss/jboss-4.0.2,
name=JBoss v4.0, id=org.eclipse.jst.server.generic.runtime.jboss4}
It is not obvious how I set the serverRootDirectory. Any ideas?
Re: new proj wizard [message #203921 is a reply to message #203915] Wed, 07 November 2007 12:26 Go to previous messageGo to next message
This is an aspect of how the JBoss adapter works. I am not 100%
positive, but you may have to cast down to the internal
RuntimeWorkingCopy class in order to access that configuration.
- Konstantin
Re: new proj wizard [message #203964 is a reply to message #203526] Wed, 07 November 2007 17:16 Go to previous messageGo to next message
Why does adding the facets occasionally (not every time) give me a
"CoreException: One or more constraints have not been staisfied"?
2007-11-07 17:12:41,791 ERROR [org.eclipse.core.runtime.CoreException:
One or more constraints have not been satisfied.]
2007-11-07 17:12:41,791 ERROR [ @
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modifyInternal(FacetedProject.java:282)]
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.access$2(FacetedProject.java:264)]
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject$1.run(FacetedProject.java:249)]
org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)]
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modify(FacetedProject.java:259)]
org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.installProjectFacet(FacetedProject.java:216)]
com.jk.applications.sce.ui.wizards.ProjectCreationAction.add EclipseProjectFacets(ProjectCreationAction.java:428)]
> methods:
> - Konstantin
Re: new proj wizard [message #203971 is a reply to message #203964] Wed, 07 November 2007 17:35 Go to previous messageGo to next message
Are you installing facets in the right order (and always in the same order)?
Re: new proj wizard [message #204319 is a reply to message #203971] Tue, 13 November 2007 08:44 Go to previous messageGo to next message
// add the java and web facets
IFacetedProject fp = ProjectFacetsManager.create(proj, true, null);
.getDefaultVersion(), null, null);
> order)?
Re: new proj wizard [message #204416 is a reply to message #203526] Wed, 14 November 2007 15:49 Go to previous message
It looks like WebFacetInstallDelegate.execute is using
WebArtifactEdit.createDeploymentDescriptor which based on what I see in
the debugger is going through a bunch of calls and eventually going
out to the internet to get the
http://www.ibm.com/webservices/wsd/j2ee_web_services_client_ 1_1.xsd
schema.
How can I include this schema in a plugin so the internet is not
ncessary to add the facet.
Previous Topic:Q about EnterpriseBean.getEjbClass()
Next Topic:Dependent project setup
Current Time: Thu Jul 24 02:35:02 EDT 2025
Powered by FUDForum. Page generated in 0.11298 seconds
