Home » Language IDEs » ServerTools (WTP) » Can not profile tomat
Can not profile tomat [message #203426] Thu, 01 November 2007 13:43 Go to next message
Originally posted by: wjfang.gmail.com
I installed TPTP 4.4.1 and WTP. I am using the integrated agent controller.
I developped a web application, and want to profile it on a tomcat 5.0
server inside Eclipse. (I have set up a Tomcat 5.0 server runtime in
Eclipse).
Now I can start my web application on the internal tomcat. Testing is fine.
But when I try to profile it, I keep getting the following error message:
"Timeout waiting for Tomcat v5.0 Server at localhost to start. Server did
not start after 45s."
The "Server timeout delay" in preference is "Normal". If I set to
"Unlimited", I have to wait forever.
Any suggestion here? Does it really require a lot of time to start up tomcat
in the profiling mode? Many thanks in advance!
Jerry
Re: Can not profile tomat [message #203449 is a reply to message #203426] Thu, 01 November 2007 16:33 Go to previous messageGo to next message
Hi Jerry,
Did you start Tomcat in profiling mode? If so, is there another instance
of Tomcat (perhaps one that you're using for testing) running?
Lawrence
>Hi,
controller.
>Eclipse).
fine.
tomcat
>Cheers,
>Jerry
Re: Can not profile tomat [message #203457 is a reply to message #203426] Thu, 01 November 2007 16:46 Go to previous messageGo to next message
Bug 202078[1] indicates that using the integrated agent controller has
problems when starting servers like Tomcat. The bug suggests the
standalone agent controller can be used instead. I don't know the
details of doing that though.
Larry
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=202078
Weijian wrote:
> Eclipse).
> Cheers,
> Jerry
Re: Can not profile tomat [message #203496 is a reply to message #203457] Fri, 02 November 2007 13:09 Go to previous message
Larry,
After I started the standalone agent controller, I can profile tomcat.
Thanks for your suggestion.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:fgddvg$4gr$1@build.eclipse.org...
> standalone agent controller can be used instead. I don't know the details
> Cheers,
> Larry
> Weijian wrote:
>> Hi,
>> controller.
>> Eclipse).
>> fine.
>> tomcat
>> Cheers,
>> Jerry
Previous Topic:eclipse update : wtp and europa
Next Topic:Is there an unrestricted API similar to IModelManager.getModelForRead(IFile)?
Current Time: Wed Jul 23 12:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.16871 seconds
