Home » Modeling » GMF (Graphical Modeling Framework) » Context Menu
Context Menu [message #203233] |
Sun, 24 August 2008 11:42  |
Originally posted by: andrestenorio.cable.net.co
How do I customize the context menu for an editor in GMF? I want to remove
the default options and add some new features to work in my graphical
editor, but I cannot find what I have to change...
Andres Tenorio
Re: Context Menu [message #203328 is a reply to message #203292] |
Mon, 25 August 2008 18:42   |
I solved part of the problem... I added new options in the context menu just
like part 3 of mindmap tutorial... but I'm still unable to remove default
options... I'm still looking for the answer.
Andres
"Manoj Mitra" <manojm@blr.interrasystems.com> wrote in message
news:g8u59e$ia$1@build.eclipse.org...
> Thanks for your reply.
> But, still I am unable to remove following menus-
> Add, Navigate, Filters, Delete From Diagram/Model, Show Property View.
> Regards,
> Manoj
> Martin Jansen wrote:
>> Manoj Mitra wrote:
>>> How have you solved the problem, I am facing the same.
>> This can be achieved using the extension point concept of plugins.xml.
>> See part 3 of the GMF Mindmap tutorial for an explanation.
>> Martin
Re: Context Menu [message #204476 is a reply to message #203328] |
Fri, 05 September 2008 02:37   |
Originally posted by: manojm.blr.interrasystems.com
Hi!
Have you found some way out?
Manoj
Andres Tenorio wrote:
> just like part 3 of mindmap tutorial... but I'm still unable to remove
> default options... I'm still looking for the answer.
> Regards,
> Andres
>> Regards,
>> Manoj
>>> plugins.xml. See part 3 of the GMF Mindmap tutorial for an explanation.
>>> Martin
Re: Context Menu [message #204642 is a reply to message #204476] |
Sun, 07 September 2008 12:12   |
Hi...
No, I haven't found a solution yet... I'm starting to think that there's no
way to delete the default context menu...
Andres
news:48C0D395.2040803@blr.interrasystems.com...
> Hi!
> Regards,
> Manoj
>> Hi,
>> Regards,
>> Andres
>>> Regards,
>>> Manoj
>>>> Martin
Re: Context Menu [message #206221 is a reply to message #206214] |
Mon, 22 September 2008 06:43   |
Hi!
Me too, have the same query.
Please suggest us.
Manoj
ye wrote:
> I'm also trying to modify the context menu,but I can't find the
> buildContextMenu() function and not even the
> DiagramEditorContextMenuProvider in the xxx.diagram.part?
> Do I need to create this .java file by myself?
> Thanks!
> Ye
> Hoang Quach Dinh wrote:
>> Hi,
>> I'm a new member.
>> I solved the problem.
>> We only need to modify method public void buildContextMenu(final
>> IMenuManager menu) of class
>> xxx.diagram.part.DiagramEditorContextMenuProvider.
>> public void buildContextMenu(final IMenuManager menu) {
>> getViewer().flush();
>> try {
>> TransactionUtil.getEditingDomain(
>> (EObject) getViewer().getContents().getModel())
>> .runExclusive(new Runnable() {
>> public void run() {
>> ContributionItemService
>> .getInstance()
>> .contributeToPopupMenu(
>> DiagramEditorContextMenuProvider.this,
>> part);
>> menu.remove(ActionIds.MENU_DIAGRAM_ADD);
>> menu.remove(ActionIds.MENU_NAVIGATE);
>> menu.remove(ActionIds.MENU_FILTERS);
>> menu.remove(ActionIds.ACTION_DELETE_FROM_MODEL);
>> menu.remove(ActionIds.ACTION_DELETE_FROM_DIAGRAM);
>> menu.remove(ActionIds.ACTION_SHOW_PROPERTIES_VIEW);
>> } catch (Exception e) {
>> ResearchDiagramEditorPlugin.getInstance().logError(
>> "Error building context menu", e);
>> Hoang Quach Dinh.Hi,
> buildContext function in the xxx.Diagram.part.
Current Time: Sun Jul 27 12:27:06 EDT 2025
Powered by FUDForum. Page generated in 0.15846 seconds
