Home » Language IDEs » ServerTools (WTP) » XDoclet Enterprise Javabean - Container Managed Entity Bean - Import attributes from table = problem
XDoclet Enterprise Javabean - Container Managed Entity Bean - Import attributes from table = problem [message #199231] Thu, 30 August 2007 21:16 Go to next message
Originally posted by: koxta.koxta.net
Hi!
I experience problems when trying to create an EJB 2.1 CMP entity bean
basing on existing table in database. I've already created a single data
source (the DB engine is MySQL 5.0.45 + JDBC mysql connector 5.0.7) and
I can browse the database using Data Source Explorer.
I've created an EJB project and want to add a new entity bean. Here's
how I fill out the forms in the CMP Entity Bean wizard.
Page 1:
Selected "Container Managed Entity Bean"
Page 2:
Project: "TestEjb" (EJB 2.1 facet is enabled there)
Folder: "\TestEjb\ejbModule"
Java package: ejbs
Class name: TestEntityBean
Superclass: java.lang.Object
Page 3:
EJB Name: TestEntity
Schema: TestEntitySCHEMA
Display Name: TestEntity
Description: An EJB named TestEntity
CMP Version: 2.x
Usecase: Import attributes from table
Page 4:
Available Connection Definitions -> selected "test" (the one I've
created before, which can be easily browsed using Data Source Explorer)
Page 5:
Table: here's the problem - there are no elements in the drop-drown list
and therefore I am unable to import the CMP attributes. Adding the
attributes manually isn't the best solution when dealing with large tables.
I can easily add new session beans with XDoclet and they're working
propery (tested numerous times). Fully expanded nodes in data source
explorer look like this:
- Databases
- test (MySQL v. 5.0.0)
- test
- Schemas
- test
Dependencies
Stored procedures
- Tables
- car
- Columns
- id [INT PK]
Dependencies
- type [VARCHAR(100)]
Dependencies
- Constraints
- Primary
Dependencies
Indexes
Triggers
User-Defined Functions
Views
- ODA Data Sources
Flat File Data Source
Web Services Data Source
XML Data Source
Also logging in manually into database server and browsing the database
gives similar results - the table is present.
I'm using WTP with latest updates fetched using download manager
(Eclipse Europe J2EE edition + Update Manager). I need to use EJB 2.1,
EJB 3.0 and way more humane/predictible ways of implementing persistence
is unfortunately not an option here :(
Does anyone know how to make things work?
Kind regards,
Jurek Bartuszek
Re: XDoclet Enterprise Javabean - Container Managed Entity Bean - Import attributes from table = pro [message #203127 is a reply to message #199231] Fri, 26 October 2007 05:25 Go to previous message
Originally posted by: marcelkoch.net.gmx.de
Hi Jurek,
I also got the same problem and I don't know how to make it work. Have
you got some new hints?
Many thanks
Marcel
Jurek Bartuszek schrieb:
> Hi!
> Page 1:
> Page 2:
> Java package: ejbs
> Page 3:
> CMP Version: 2.x
> Page 4:
> Page 5:
> - Databases
> - test
> - Schemas
> - test
> Dependencies
> Stored procedures
> - Tables
> - car
> - Columns
> - id [INT PK]
> Dependencies
> Dependencies
> - Constraints
> - Primary
> Dependencies
> Indexes
> Triggers
> Views
> - ODA Data Sources
> XML Data Source
> Kind regards,
> Jurek Bartuszek
Previous Topic:WTP 2.0.1 - Perm gen space errors
Next Topic:Windows, Tomcat, classpath debugging
Current Time: Sun Jul 27 16:12:36 EDT 2025
Powered by FUDForum. Page generated in 0.03741 seconds
