Home » Language IDEs » ServerTools (WTP) » Help with WSDL validation error
Help with WSDL validation error [message #202667] Fri, 19 October 2007 08:54 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hello!
After creating a WSDL from a Java class using Axis2 1.3 Eclipse plugin,
I get a WSDL file on which Eclipse gives me a validation error:
src-resolve.4.2: Error resolving component
'ns0:FailedConfigurationException'. It was detected that
'ns0:FailedConfigurationException' is in namespace
'http://ticketFramework.webservice.cardinis.com/xsd', but components
from this namespace are not referenceable from schema document
'file:///C:/<complete-path> /WEB-INF/services/accessServices/META-INF/accessServices.wsd l'.
If this is the incorrect namespace, perhaps the prefix of
'ns0:FailedConfigurationException' needs to be changed. If this is the
correct namespace, then an appropriate 'import' tag should be added to
What does this error mean? Why is it given?
This is a fragment of the WSDL:
<wsdl:definitions xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:axis2="http://access.webservice.cardinis.cardinis.com"
xmlns:ns1="http://access.webservice.cardinis.cardinis.com/xsd"
xmlns:wsaw="http://www.w3.org/2006/05/addressing/wsdl"
xmlns:http="http://schemas.xmlsoap.org/wsdl/http/"
xmlns:ns0="http://ticketFramework.webservice.cardinis.com/xsd"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:mime="http://schemas.xmlsoap.org/wsdl/mime/"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:soap12="http://schemas.xmlsoap.org/wsdl/soap12/"
targetNamespace="http://access.webservice.cardinis.cardinis.com">
<wsdl:types>
<xs:schema
xmlns:ax21="http://ticketFramework.webservice.cardinis.com/xsd"
attributeFormDefault="qualified" elementFormDefault="qualified"
targetNamespace="http://ticketFramework.webservice.cardinis.com/xsd">
<xs:complexType name="FailedConfigurationException">
<xs:complexContent>
<xs:extension base="ns1:Exception">
<xs:sequence />
</xs:extension>
</xs:complexContent>
</xs:complexType>
Any suggestion would be really appreciated.
Mauro.
Re: Help with WSDL validation error [message #202678 is a reply to message #202667] Fri, 19 October 2007 09:33 Go to previous messageGo to next message
Originally posted by: valentinbaciu.hotmail.com
It's a bit hard to be sure without seeing the entire file: the error is
trying to say that the complex type FailedConfigurationException is
extending a type from perhaps another (inline?) schema and that schema is
not imported in the schema that declares FailedConfigurationException.
"Mauro Molinari" <mauro.molinari@cardinis.com> wrote in message
news:ffa9ec$1bs$1@build.eclipse.org...
> Hello!
> After creating a WSDL from a Java class using Axis2 1.3 Eclipse plugin, I
> 'http://ticketFramework.webservice.cardinis.com/xsd', but components from
> <wsdl:types>
> <xs:schema
> <xs:complexContent>
> <xs:sequence />
> </xs:extension>
> </xs:complexType>
> Mauro.
Re: Help with WSDL validation error [message #202689 is a reply to message #202678] Fri, 19 October 2007 10:39 Go to previous messageGo to next message
Hi Valentin,
thank you for your help!
I'm attaching the whole content of the WSDL file. This file has been
generated from a Java class using Axis 1.3 Eclipse plugin, so it should
not (I think...) depend on any other schema.
So, I have to guess that this WSDL is not completely self-defined?
(sorry if my questions are stupid, but I'm not experienced with WSDL and
complex XML...).
These are the signatures of the two methods of AccessServices class file
I want to expose as a web service:
1) public String loginByUsernamePassword(String username, String
password) throws FailedConfigurationException, InvalidArgumentException,
GenericTicketingException{
2) public void logout(String ticket) throws
GenericTicketingException {
Please note that all those three exceptions are custom exceptions that
extend java.lang.Exception.
Here's the complete WSDL:
<wsdl:types>
<xs:schema
<xs:complexContent>
<xs:sequence />
</xs:extension>
</xs:complexType>
<xs:complexType name="InvalidArgumentException">
<xs:complexContent>
<xs:sequence />
</xs:extension>
</xs:complexType>
<xs:complexType name="GenericTicketingException">
<xs:complexContent>
<xs:sequence />
</xs:extension>
</xs:complexType>
</xs:schema>
<xs:schema
xmlns:xsd="http://access.webservice.cardinis.cardinis.com/xsd"
targetNamespace="http://access.webservice.cardinis.cardinis.com/xsd">
<xs:complexType name="Exception">
<xs:sequence>
<xs:element minOccurs="0" name="Exception" nillable="true"
type="xs:anyType" />
</xs:sequence>
</xs:complexType>
<xs:element name="FailedConfigurationException">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" name="FailedConfigurationException"
nillable="true" type="ns0:FailedConfigurationException" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="InvalidArgumentException">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" name="InvalidArgumentException"
nillable="true" type="ns0:InvalidArgumentException" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="GenericTicketingException">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" name="GenericTicketingException"
nillable="true" type="ns0:GenericTicketingException" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="loginByUsernamePassword">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" name="username" nillable="true"
type="xs:string" />
<xs:element minOccurs="0" name="password" nillable="true"
type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="loginByUsernamePasswordResponse">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" name="return" nillable="true"
type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="logout">
<xs:complexType>
<xs:sequence>
<xs:element minOccurs="0" name="ticket" nillable="true"
type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
</wsdl:types>
<wsdl:message name="logoutRequest">
<wsdl:part name="parameters" element="ns1:logout" />
</wsdl:message>
<wsdl:message name="logoutResponse" />
<wsdl:message name="FailedConfigurationException">
element="ns1:FailedConfigurationException" />
</wsdl:message>
<wsdl:message name="InvalidArgumentException">
<wsdl:part name="parameters" element="ns1:InvalidArgumentException" />
</wsdl:message>
<wsdl:message name="GenericTicketingException">
<wsdl:part name="parameters" element="ns1:GenericTicketingException" />
</wsdl:message>
<wsdl:message name="loginByUsernamePasswordRequest">
<wsdl:part name="parameters" element="ns1:loginByUsernamePassword" />
</wsdl:message>
<wsdl:message name="loginByUsernamePasswordResponse">
element="ns1:loginByUsernamePasswordResponse" />
</wsdl:message>
<wsdl:portType name="AccessServicesPortType">
<wsdl:operation name="logout">
<wsdl:input message="axis2:logoutRequest" wsaw:Action="urn:logout" />
<wsdl:output message="axis2:logoutResponse"
wsaw:Action="urn:logoutResponse" />
<wsdl:fault message="axis2:FailedConfigurationException"
wsaw:Action="urn:logoutFailedConfigurationException" />
<wsdl:fault message="axis2:InvalidArgumentException"
wsaw:Action="urn:logoutInvalidArgumentException" />
<wsdl:fault message="axis2:GenericTicketingException"
wsaw:Action="urn:logoutGenericTicketingException" />
</wsdl:operation>
<wsdl:operation name="loginByUsernamePassword">
<wsdl:input message="axis2:loginByUsernamePasswordRequest"
wsaw:Action="urn:loginByUsernamePassword" />
<wsdl:output message="axis2:loginByUsernamePasswordResponse"
wsaw:Action="urn:loginByUsernamePasswordResponse" />
wsaw:Action="urn:loginByUsernamePasswordFailedConfigurationException " />
wsaw:Action="urn:loginByUsernamePasswordInvalidArgumentException " />
wsaw:Action="urn:loginByUsernamePasswordGenericTicketingException " />
</wsdl:operation>
</wsdl:portType>
<wsdl:binding name="AccessServicesSOAP11Binding"
type="axis2:AccessServicesPortType">
<soap:binding transport="http://schemas.xmlsoap.org/soap/http"
style="document" />
<soap:operation soapAction="urn:logout" style="document" />
<wsdl:input>
<soap:body use="literal" />
</wsdl:input>
<wsdl:output>
</wsdl:output>
<wsdl:fault name="FailedConfigurationException">
<soap:fault use="literal" name="FailedConfigurationException" />
</wsdl:fault>
<wsdl:fault name="InvalidArgumentException">
<soap:fault use="literal" name="InvalidArgumentException" />
</wsdl:fault>
<wsdl:fault name="GenericTicketingException">
<soap:fault use="literal" name="GenericTicketingException" />
</wsdl:fault>
</wsdl:operation>
<soap:operation soapAction="urn:loginByUsernamePassword"
style="document" />
<wsdl:input>
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:fault>
</wsdl:fault>
</wsdl:fault>
</wsdl:operation>
</wsdl:binding>
<wsdl:binding name="AccessServicesSOAP12Binding"
<soap12:binding transport="http://schemas.xmlsoap.org/soap/http"
style="document" />
<soap12:operation soapAction="urn:logout" style="document" />
<wsdl:input>
<soap12:body use="literal" />
</wsdl:input>
<wsdl:output>
</wsdl:output>
<soap12:fault use="literal" name="FailedConfigurationException" />
</wsdl:fault>
<soap12:fault use="literal" name="InvalidArgumentException" />
</wsdl:fault>
<soap12:fault use="literal" name="GenericTicketingException" />
</wsdl:fault>
</wsdl:operation>
<soap12:operation soapAction="urn:loginByUsernamePassword"
style="document" />
<wsdl:input>
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:fault>
</wsdl:fault>
</wsdl:fault>
</wsdl:operation>
</wsdl:binding>
<wsdl:binding name="AccessServicesHttpBinding"
<http:binding verb="POST" />
<http:operation location="AccessServices/logout" />
<wsdl:input>
<mime:content type="text/xml" part="logout" />
</wsdl:input>
</wsdl:operation>
<http:operation location="AccessServices/loginByUsernamePassword" />
<wsdl:input>
<mime:content type="text/xml" part="loginByUsernamePassword" />
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="AccessServices">
<wsdl:port name="AccessServicesSOAP11port_http"
binding="axis2:AccessServicesSOAP11Binding">
<soap:address
location="http://localhost:8080/axis2/services/AccessServices" />
</wsdl:port>
<wsdl:port name="AccessServicesSOAP12port_http"
binding="axis2:AccessServicesSOAP12Binding">
<soap12:address
</wsdl:port>
<wsdl:port name="AccessServicesHttpport"
binding="axis2:AccessServicesHttpBinding">
<http:address
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
Mauro.
Re: Help with WSDL validation error [message #202706 is a reply to message #202689] Fri, 19 October 2007 12:11 Go to previous messageGo to next message
> <wsdl:types>
> <xs:schema
I think you need this here:
<xs:import
namespace="http://access.webservice.cardinis.cardinis.com/xsd"/>
Otherwise, the schema doesn't know where ns1:Exception comes from.
> <xs:complexContent>
> <xs:sequence />
> </xs:extension>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence />
> </xs:extension>
> </xs:complexType>
> <xs:complexContent>
> <xs:sequence />
> </xs:extension>
> </xs:complexType>
> </xs:schema>
Depending on the WSDL editor and validator, you may need to flip these
definitions around, so that the one below comes before the one above as
well.
Personally though, I would create a new schema that imported or included
each of these itself. Multiple schemas in the wsdl:type definition is
a gray area amongst tools.
> <xs:schema
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> type="xs:string" />
> type="xs:string" />
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> type="xs:string" />
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> <xs:complexType>
> <xs:sequence>
> type="xs:string" />
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> </xs:schema>
> </wsdl:types>
Re: Help with WSDL validation error [message #202754 is a reply to message #202706] Sun, 21 October 2007 22:41 Go to previous messageGo to next message
> <xs:import
I think David's nailed the problem. It's possible the Axis emitter is
generating invalid XSD. Although there are different views on whether
import statements are required for other inline schemas in the same WSDL
document the XML schema spec is states that import statements are required
in schemas for each foreign component that the schema references:
"At least two conditions must be satisfied for a reference to be made to a
foreign component: there must be not only a means of addressing such
foreign components but also a signal to schema-aware processors that a
schema document contains such references. Thus, the <import> element
information item identifies namespaces used in external component
references, i.e. those whose ·QName· identifies them as coming from a
namespace different from that of the enclosing schema document's
targetNamespace. " [1]
[1] http://www.w3.org/TR/xmlschema11-1/#composition-schemaImport
Lawrence
Re: Help with WSDL validation error [message #202763 is a reply to message #202706] Mon, 22 October 2007 04:36 Go to previous messageGo to next message
> <xs:import
Thank you David, thank you Lawrence.
Starting from this hint, I tried to add the option in Java2WSDL to add
the generated schema for java.lang.Exception, too.
The resulting XML doesn't have the problem described earlier, but has
other problems:
- a problem with the ax21 namespace: I'm not expert in XML, but I think
that the namespace definition
xmlns:ax21="http://ticketFramework.webservice.cardinis.com/xsd" should
be in <wsdl:definitions> rather than in <wsdl:types>...
- many errors like:
cvc-identity-constraint.4.2.2: Duplicate key value
[FailedConfigurationException] declared for identity constraint
"message" of element "definitions".
Any suggestion for this? May it be a problem in the relative position of
the entries, like David suggested?
- cvc-complex-type.2.4.a: Invalid content was found starting with
element 'wsdl:fault'. One of
'{"http://schemas.xmlsoap.org/wsdl/":output}' is expected. (on line 166)
Any suggestion for this, too?
Here is the whole generated WDSL:
<wsdl:definitions
xmlns:ns="http://access.webservice.cardinis.cardinis.com/xsd"
<wsdl:types>
<xs:schema
type="ax21:FailedConfigurationException" />
<xs:complexContent>
<xs:extension base="xs:Exception">
<xs:sequence />
</xs:extension>
</xs:complexType>
type="ax21:InvalidArgumentException" />
<xs:complexContent>
<xs:sequence />
</xs:extension>
</xs:complexType>
type="ax21:GenericTicketingException" />
<xs:complexContent>
<xs:sequence />
</xs:extension>
</xs:complexType>
</xs:schema>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
<xs:element name="FailedConfigurationExceptionFault">
<xs:complexType>
<xs:sequence>
<xs:element name="FailedConfigurationException" nillable="true"
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="InvalidArgumentExceptionFault">
<xs:complexType>
<xs:sequence>
<xs:element name="InvalidArgumentException" nillable="true"
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:element name="GenericTicketingExceptionFault">
<xs:complexType>
<xs:sequence>
<xs:element name="GenericTicketingException" nillable="true"
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
<xs:element name="username" nillable="true" type="xs:string" />
<xs:element name="password" nillable="true" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
<xs:element name="return" nillable="true" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
</xs:sequence>
</xs:complexType>
</xs:element>
<xs:complexType>
<xs:sequence>
<xs:element name="ticket" nillable="true" type="xs:string" />
</xs:sequence>
</xs:complexType>
</xs:element>
</xs:schema>
</wsdl:types>
<wsdl:message name="loginByUsernamePasswordMessage">
<wsdl:part name="part1" element="ns:loginByUsernamePassword" />
</wsdl:message>
<wsdl:message name="loginByUsernamePasswordResponseMessage">
<wsdl:part name="part1" element="ns:loginByUsernamePasswordResponse" />
</wsdl:message>
<wsdl:part name="part1" element="ax21:FailedConfigurationException" />
</wsdl:message>
<wsdl:part name="part1" element="ax21:InvalidArgumentException" />
</wsdl:message>
<wsdl:part name="part1" element="ax21:GenericTicketingException" />
</wsdl:message>
<wsdl:message name="logoutMessage">
<wsdl:part name="part1" element="ns:logout" />
</wsdl:message>
</wsdl:message>
</wsdl:message>
</wsdl:message>
<wsdl:input xmlns:wsaw="http://www.w3.org/2006/05/addressing/wsdl"
message="axis2:loginByUsernamePasswordMessage" />
<wsdl:output xmlns:wsaw="http://www.w3.org/2006/05/addressing/wsdl"
message="axis2:loginByUsernamePasswordResponseMessage"
</wsdl:operation>
wsaw:Action="urn:logout" message="axis2:logoutMessage" />
</wsdl:operation>
</wsdl:portType>
style="document" />
style="document" />
<wsdl:input>
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:fault>
</wsdl:fault>
</wsdl:fault>
</wsdl:operation>
<wsdl:input>
</wsdl:input>
</wsdl:fault>
</wsdl:fault>
</wsdl:fault>
</wsdl:operation>
</wsdl:binding>
style="document" />
style="document" />
<wsdl:input>
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:fault>
</wsdl:fault>
</wsdl:fault>
</wsdl:operation>
<wsdl:input>
</wsdl:input>
</wsdl:fault>
</wsdl:fault>
</wsdl:fault>
</wsdl:operation>
</wsdl:binding>
<wsdl:port name="AccessServicesSOAP11port"
<soap:address
</wsdl:port>
<wsdl:port name="AccessServicesSOAP12port"
<soap12:address
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
> well.
I see... so, if I created multiple schemas for each complex type, I
could share them between multiple WDSLs, couldn't I?
It sounds interesting...
The main problem is that I was starting using Axis2's Java2WSDL thinking
that it should make all the work for me, but it seems that it actually
has some serious problems managing methods that can launch exceptions...
Axis2 online documentation doesn't give any example of using the
bottom-up approach with methods that are more complex than simple
"hello-world" cases...
I would be grateful if someone had any hints of where I could find some
useful documentation.
Mauro.
Re: Help with WSDL validation error [message #202786 is a reply to message #202763] Mon, 22 October 2007 09:56 Go to previous messageGo to next message
Comments in line:
No, you should be able to define it on the xs:schema. However, since you
reference it from outside the xs:schema, you probably should have it
defined at thw WSDL:definition level as well, to make it visible to the
system.
> - many errors like:
This is because you have two wsdl:message names with the same entry.
You have two FailedConfigurationException message entries defined.
In your operation logout, you need an empty wsdl:output before your
wsdl:fault.
I always recommend a top down approach if you have control over what you
are designing. I never rely on tools to figure out what I want, you
usually have to do some tweaking to what they generate to make sure they
aren't confused.
Re: Help with WSDL validation error [message #202807 is a reply to message #202786] Mon, 22 October 2007 13:14 Go to previous messageGo to next message
>aren't confused.
I second this comment. A top-down approach (authoring the WSDL doc
yourself and then generating a Java or other stub) allows you to create a
clean interface. You can use this approach with an existing implementation
by hooking up the generated code to your existing implementation.
Lawrence
Re: Help with WSDL validation error [message #202906 is a reply to message #202807] Tue, 23 October 2007 09:08 Go to previous message
Thank you for your suggestions.
In fact, this is the approach I will adopt, although I was searching for
a quicker way as a short-term solution.
Mauro.
Previous Topic:Validation of web.xml for 2.5 projects
Next Topic:Problems with WSDL Validation with WS-I
Current Time: Tue Oct 28 13:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.06138 seconds
