Home » Eclipse Projects » GEF » selection and creation commands
selection and creation commands [message #202453] Wed, 09 November 2005 15:51 Go to next message
Hi all,
I have a GEF style question. I have a GEF editor that allows the user to
create and delete new model objects (and therefore the associated edit
parts). This creation process is may be the result of an action bound to a
key command or what have you. My editor uses only a SelectionTool. I'm not
using a palette for
When a new model object is created I want the associated edit part to become
the only selected editpart. Similarly when undo'ing the delete of an edit
part I want the restored edit part to be selected.
This is all quite doable but as a result I find myself having to pass the
EditPartViewer to the commands so the selection can be manipulated in the
commands' execute and undo methods. This seems like a nasty pollution of the
commands which heretofore had been quite pure in that they knew only of
model objects. Is there a better way to handle this?
Re: selection and creation commands [message #202461 is a reply to message #202453] Wed, 09 November 2005 16:23 Go to previous message
I haven't tried it out, but I would try to select the newly created EditPart
within one of its methods that only gets called when it is freshly created.
AbstractGraphicalEditPart.createFigure() or EditPart#activate() comes to
mind. Naturally you would also have to somehow distinguish between the
opening of your diagram and the addition of a new object.
"Eric Wasserman" <ewasserman@voxify.com> wrote in message
news:BF97A160.14481%ewasserman@voxify.com...
> Hi all,
> using a palette for
> become
> the
Previous Topic:XOR-Bug (and Mac and solution)
Next Topic:Drag And Drop from View to Editor
Current Time: Sun Jul 27 13:48:30 EDT 2025
Powered by FUDForum. Page generated in 0.03169 seconds
