Home » Language IDEs » ServerTools (WTP) » XML Form Editor using WTP's Structured Text Editor
XML Form Editor using WTP's Structured Text Editor [message #202002] Fri, 12 October 2007 15:38 Go to next message
Originally posted by: italdesign99.hotmail.com
I am in the process of creating an XML Eclipse Forms Editor: Here is what
I have so far before I get to my question:
The model is DOM (ie.org.w3c.dom)
The text editor I am using is an instance of
org.eclipse.wst.sse.ui.StructuredTextEditor
The form pages consist of a variety of widgets like lists, combo-boxes,
checkboxes, text boxes and fields, etc.
I did a little test and created a DOM label provider and content provider
and had it populate a treeviewer. This worked pretty nicely.
Is there anything like this I can use for a FormPage, like settign a
viewer on a form page or on each individual widget which can have a
content provider and label provider set to it that way whenever the
underlying model changes the affected widget's content will change
accordingly.
I reasearched into this and didn't find any such eclispe api that would
help me out in this fairly easy way.
Maybe in WTP I could use it's IStateModelListener to help let me know when
soemething changes in the xml model, iterate through the model,and refresh
the form page with an update.
Please let me know what you think?
Re: XML Form Editor using WTP's Structured Text Editor [message #202060 is a reply to message #202002] Sat, 13 October 2007 02:31 Go to previous messageGo to next message
"Muneer" <italdesign99@hotmail.com> wrote in message
news:f719e4e924a1389e258297142daea50f$1@www.eclipse.org...
I would quite interested by that too, but in the context of the Visual
editor project.
Is your project open source?
Read that blog post:
http://dev.eclipse.org/blogs/wonk/2007/10/12/fighting-aids-w ith-open-source/
Cordially
Re: XML Form Editor using WTP's Structured Text Editor [message #202067 is a reply to message #202060] Sat, 13 October 2007 11:20 Go to previous messageGo to next message
> editor project.
> Cordially
Might want to look at the following, it's based on WTP 1.5 though:
http://www.alphaworks.ibm.com/tech/vxd
Re: XML Form Editor using WTP's Structured Text Editor [message #202080 is a reply to message #202060] Sat, 13 October 2007 12:26 Go to previous messageGo to next message
> editor project.
> Cordially
You may want to check out the Apogee project:
http://www.eclipse.org/apogee/
Re: XML Form Editor using WTP's Structured Text Editor [message #202246 is a reply to message #202080] Mon, 15 October 2007 10:59 Go to previous messageGo to next message
I checked out the XForms Editor from Apogee; It defenitley looks very
useful, however the issuse is that I already have all the form pages for
my editor created and I just need help figuring out the simplest way of
using WST's StructuredTextEditor, and StructuredModel to listen for
changes in the xml document and have it update the fields in my
FormPages. Similarly, The reverse (ie. listening for changes in the form
page for changes on any of the widgets, and then modifying the xml source
appropriately) is also an anrea need some help. I know how to imitate,
WTP's XML editor with the design view, source view,and content outline
link, but when it comes to substituting the treeviewer with Eclipse Forms,
I can't find any API that will help me do it easily like just providing
label and content providers.
P.S.
I think I'l join the fight against aids, too : )
Re: XML Form Editor using WTP's Structured Text Editor [message #202325 is a reply to message #202246] Tue, 16 October 2007 09:37 Go to previous messageGo to next message
Muneer wrote:
> form page for changes on any of the widgets, and then modifying the xml
> source appropriately) is also an anrea need some help. I know how to
> imitate, WTP's XML editor with the design view, source view,and content
> outline link, but when it comes to substituting the treeviewer with
> Eclipse Forms, I can't find any API that will help me do it easily like
> just providing label and content providers.
You may want to check out the code for the Web Page Designer in the the
WTP jst project. It adds it's own graphical designer along with a
structured text editor. It might give you some ideas on how to
implement this. Unfortunately, I don't know that code, but maybe Nitin
or another committer can answer the question.
Re: XML Form Editor using WTP's Structured Text Editor [message #202448 is a reply to message #202067] Wed, 17 October 2007 00:24 Go to previous messageGo to next message
"David Carver" <d_a_carver@yahoo.com> wrote in message
news:feqk51$ehu$1@build.eclipse.org...
Thanks... quite interesting. I'll be reaching out to them.
In the meantime we also got interestsing volunteer contributions that showed
up for the Visual Editor.
Cheers, Philippe
http://www.nexb.com - http://eclipse.org/ve - http://eclipse.org/atf -
http://easyeclipse.org - http://phpeclipse.net
Re: XML Form Editor using WTP's Structured Text Editor [message #202455 is a reply to message #202080] Wed, 17 October 2007 00:31 Go to previous messageGo to next message
news:feqo0q$m44$1@build.eclipse.org...
Apogee is an EclipseForms editor using Xforms, not a Visual XForms designer.
Akin to an SWT XForms "player".
What we need is authoring, not rendering. There are plenty of renderers.
Cheers, Philippe
Re: XML Form Editor using WTP's Structured Text Editor [message #202463 is a reply to message #202246] Wed, 17 October 2007 00:32 Go to previous message
news:e0ea238055e0229e49d1bb5cb53483ed$1@www.eclipse.org...
> P.S.
That is cool. I am trying to structure the talk in the ve-dev mailimg if you
want to participate.
Cordially
Philippe
Previous Topic:.class.getResource() returns wrong directory?
Next Topic:[ANN] ATF project new name search: final voting round starts- PLEASE VOTE ... http://www.surveymonke
Current Time: Thu Nov 06 21:48:04 EST 2025
Powered by FUDForum. Page generated in 0.04818 seconds
