Home » Newcomers » Newcomers » Characters cannot be mapped
Characters cannot be mapped [message #201997] Wed, 28 March 2007 10:28 Go to next message
Originally posted by: chris.riley.cra-arc.gc.ca
Hello! Newcommer here. Not sure if this is the correct forum for this. I
hope someone will direct me if I have posted this to the wrong place.
I've noticed that Eclipse (version 3.2.1) won't allow me to save a web
file who's special characters are not compliant with the character coding
that has been declared for that web page file.
Eclipse pops up a message informing me that some characters cannot be
mapped to ISO-8859-1 (this is the character encoding I use for my web
pages). And, I can't save the file until I clean up those bad characters.
It's a featuer I don't need since I use a HTML validator that will point
out these bad characters, AND tell me exactly which ones they are and
where they are located in the file. Eclipse doesn't do that.
Is there a way to turn this off so that I can save in Eclipse, regardless?
Much thanx,
Chris
Re: Characters cannot be mapped [message #202005 is a reply to message #201997] Wed, 28 March 2007 10:43 Go to previous messageGo to next message
Chris,
This sounds likely to be a question about tools provided by WTP. I'm
pretty sure there are ways to turn off the validators (probably via
preference) but I don't know how. I've added the WTP newsgroup to the
"to" list, so hopefully someone will see it in that newsgroup and answer.
> I hope someone will direct me if I have posted this to the wrong place.
> coding that has been declared for that web page file.
> point out these bad characters, AND tell me exactly which ones they
> are and where they are located in the file. Eclipse doesn't do that.
> regardless?
> Much thanx,
> Chris
Re: Characters cannot be mapped [message #202179 is a reply to message #202005] Thu, 29 March 2007 06:05 Go to previous messageGo to next message
Ed Merks wrote:
> Chris,
Nope, as upon save using the wrong encoding the character(s) would be
destroyed. Either use a different encoding or valid characters.
Dani
> (probably via preference) but I don't know how. I've added the WTP
> newsgroup to the "to" list, so hopefully someone will see it in that
>> this. I hope someone will direct me if I have posted this to the
>> wrong place.
>> web file who's special characters are not compliant with the
>> character coding that has been declared for that web page file.
>> characters.
>> regardless?
>> Much thanx,
>> Chris
Re: Characters cannot be mapped [message #202220 is a reply to message #202179] Thu, 29 March 2007 10:45 Go to previous messageGo to next message
Thanx folks.
Re: Characters cannot be mapped [message #202478 is a reply to message #202179] Fri, 30 March 2007 13:54 Go to previous messageGo to next message
> Dani
Dani, I don't think you understand: there is no "upon save" in my scenario.
Using a different character encoding on the web pages is not an option.
It's not that I'm trying to add invalid characters.
I'm not dissing Eclipse at all here, rather making a recommendation:
Eclipse should allow files to be saved ragardless of characters. The
function, in its current state, only goes part way in to the realm of
"character validation". If the developers want to implement validation in
Eclipse, it should be expanded to include, for example, highlighting the
lines where the bad characters exists, and underlining the offending
characters, rather than just refusing to save.
Re: Characters cannot be mapped [message #202491 is a reply to message #202478] Fri, 30 March 2007 14:33 Go to previous messageGo to next message
>> Dani
> in Eclipse, it should be expanded to include, for example, highlighting
> the lines where the bad characters exists, and underlining the offending
I'm not sure if it will solve your problem but you could try turning off
the validator under window > preferences > validation.
Re: Characters cannot be mapped [message #203023 is a reply to message #202491] Tue, 03 April 2007 12:52 Go to previous message
Thanx Mark, but no go.
Chris
Previous Topic:Eclipse SDK on Suse linux
Next Topic:Setting initial position of a PopupDialog
Current Time: Tue Nov 04 21:48:41 EST 2025
Powered by FUDForum. Page generated in 0.10845 seconds
