Home » Archived » BIRT » Birt Report and PDF
Birt Report and PDF [message #202148] Tue, 21 November 2006 12:03 Go to next message
Originally posted by: barrygwells.gmail.com
I have a report which displays fine as HTML using the below http:, but
when I add &__format=pdf to the end, it just sits there and never displays
the report. I've tried it on several system (linux and Windows) and I get
the same results
This runs fine
http://xxx.xxx.xxx.xxx:8080/birt-viewer/run?__report=Report/ CaseFlags.rptdesign
when I tell it pdf i get nothing.
http://xxx.xxx.xxx.xxx:8080/birt-viewer/run?__report=Report/ CaseFlags.rptdesign&__format=pdf
I have the iText-1.3.jar in the below folder.
/Apache%20Software%20Foundation/Tomcat%205.5/webapps/birt-vi ewer/WEB-INF/platform/plugins/com.lowagie.itext/lib
Did I miss something? Any help would be appreciated.
Re: Birt Report and PDF [message #202151 is a reply to message #202148] Tue, 21 November 2006 12:29 Go to previous messageGo to next message
Barry,
What happens when you try the sample report?
ie
http://localhost:8080/birt-viewer/run?__report=test.rptdesig n&sample=my+parameter&__format=pdf
BTW what version of BIRT are you using?
Jason
"barry" <barrygwells@gmail.com> wrote in message
news:9530b4c09e04ba965e300416a641e04f$1@www.eclipse.org...
>the same results
> This runs fine
Re: Birt Report and PDF [message #202168 is a reply to message #202151] Tue, 21 November 2006 13:44 Go to previous messageGo to next message
I'm using 2.1.1 and I get the same results using the test report.
Re: Birt Report and PDF [message #202237 is a reply to message #202151] Tue, 21 November 2006 15:12 Go to previous message
I found the problem... I didn't update the viewer on tomcat. Dev version
was 2.1.1 and the tomcat version was 2.1.0. It now works.
Previous Topic:Display date report parameter in specific format
Next Topic:Data Set Error
Current Time: Fri Jul 18 20:58:16 EDT 2025
Powered by FUDForum. Page generated in 0.04304 seconds
