Home » Eclipse Projects » Eclipse Platform » Classpath/Console/System.out
Classpath/Console/System.out [message #201034] Tue, 24 February 2004 14:41 Go to next message
1. How can I see Classpath in Console which is used to invoke the
Application.
2. How can I tell the System.err not show up in console but in a Seperate
error file. Also, can I specify the Console output to appear in a Seperate
Persistent file.
Thanks.
Re: Classpath/Console/System.out [message #201049 is a reply to message #201034] Tue, 24 February 2004 15:03 Go to previous messageGo to next message
> Application.
You cannot see it in the Console.
You can see it by using the context menu for the Debug Target or Process.
Select Properties. The process information shows the classpath etc.
> Persistent file.
You cannot.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=23064
Darins
Re: Classpath/Console/System.out [message #201081 is a reply to message #201049] Tue, 24 February 2004 15:39 Go to previous messageGo to next message
> > Application.
> > Persistent file.
> You cannot.
> Darins
Thanks. Do you have any idea by when will they get this fixed?
Re: Classpath/Console/System.out [message #201095 is a reply to message #201081] Tue, 24 February 2004 15:56 Go to previous messageGo to next message
"rohitsoftware" <rohitsoftware@yahoo.com> wrote in message
news:c1gcq8$9ms$1@eclipse.org...
> > > Application.
Process.
Seperate
Seperate
> > > Persistent file.
> > You cannot.
> > Darins
Currently slated to be available for 3.0. You can add your vote / patch that
may increase the priority of that particular bug.
Darins
Re: Classpath/Console/System.out [message #202146 is a reply to message #201095] Thu, 26 February 2004 06:34 Go to previous message
Originally posted by: wai-lun.cheng.mythales-is.com
You can see the classpath using this code :
System.out.println("CLASSPATH = " + System.getProperty("java.class.path"));
> > > > Application.
> Process.
> Seperate
> Seperate
> > > > Persistent file.
> > > You cannot.
> > > Darins
> Darins
Previous Topic:current path in classpath
Next Topic:show a file in a different directory
Current Time: Mon Oct 20 19:31:40 EDT 2025
Powered by FUDForum. Page generated in 0.04505 seconds
