| XML Form Editor using WTP's Structured Text Editor [message #202002] |
Fri, 12 October 2007 15:38  |
Originally posted by: italdesign99.hotmail.com
I am in the process of creating an XML Eclipse Forms Editor: Here is what
I have so far before I get to my question:
The model is DOM (ie.org.w3c.dom)
The text editor I am using is an instance of
org.eclipse.wst.sse.ui.StructuredTextEditor
The form pages consist of a variety of widgets like lists, combo-boxes,
checkboxes, text boxes and fields, etc.
I did a little test and created a DOM label provider and content provider
and had it populate a treeviewer. This worked pretty nicely.
Is there anything like this I can use for a FormPage, like settign a
viewer on a form page or on each individual widget which can have a
content provider and label provider set to it that way whenever the
underlying model changes the affected widget's content will change
accordingly.
I reasearched into this and didn't find any such eclispe api that would
help me out in this fairly easy way.
Maybe in WTP I could use it's IStateModelListener to help let me know when
soemething changes in the xml model, iterate through the model,and refresh
the form page with an update.
Please let me know what you think?
| Re: XML Form Editor using WTP's Structured Text Editor [message #202246 is a reply to message #202080] |
Mon, 15 October 2007 10:59   |
I checked out the XForms Editor from Apogee; It defenitley looks very
useful, however the issuse is that I already have all the form pages for
my editor created and I just need help figuring out the simplest way of
using WST's StructuredTextEditor, and StructuredModel to listen for
changes in the xml document and have it update the fields in my
FormPages. Similarly, The reverse (ie. listening for changes in the form
page for changes on any of the widgets, and then modifying the xml source
appropriately) is also an anrea need some help. I know how to imitate,
WTP's XML editor with the design view, source view,and content outline
link, but when it comes to substituting the treeviewer with Eclipse Forms,
I can't find any API that will help me do it easily like just providing
label and content providers.
P.S.
I think I'l join the fight against aids, too : )
| Re: XML Form Editor using WTP's Structured Text Editor [message #202325 is a reply to message #202246] |
Tue, 16 October 2007 09:37   |
Muneer wrote:
> form page for changes on any of the widgets, and then modifying the xml
> source appropriately) is also an anrea need some help. I know how to
> imitate, WTP's XML editor with the design view, source view,and content
> outline link, but when it comes to substituting the treeviewer with
> Eclipse Forms, I can't find any API that will help me do it easily like
> just providing label and content providers.
You may want to check out the code for the Web Page Designer in the the
WTP jst project. It adds it's own graphical designer along with a
structured text editor. It might give you some ideas on how to
implement this. Unfortunately, I don't know that code, but maybe Nitin
or another committer can answer the question.
FUDForum. Page generated in 0.03746 seconds
