Home » Language IDEs » ServerTools (WTP) » WAR export --> Module name is invalid.
WAR export --> Module name is invalid. [message #201994] Fri, 12 October 2007 14:43 Go to next message
Originally posted by: rbaril.forecasttech.com
As soon as I try entering a module name, no matter what I type, it
displays the error "Module name is invalid." at the top of the dialog box.
I've been unable to export projects as a WAR file using 3.3 (Europa) or
3.2. I am able to do it under 3.1 however. I've STFW extensively only to
find similar questions left unanswered. I'm running Ubuntu 7.04. Any
ideas would be greatly appreciated.
Rick Baril
Re: WAR export --> Module name is invalid. [message #202241 is a reply to message #201994] Mon, 15 October 2007 10:05 Go to previous message
Hi Rick,
You should not edit the "Web module" field in a normal case.
The "Web module" name references to an existing and open Dynamic Web Project
in your workspace. This is why you have a drop-down list where you can
select from all open Dynamic Web Projects in your workspace.
If you give a name in the "Web module" field that does not reference an
existing project, or references a project that is closed, or references a
project that is not a Dynamic Web Project, then the "Module name is invalid"
error is displayed.
If you need different Context Root for your web project and this is why you
try to export it with different name, then you can change the Context Root
with the following steps:
1. Right-click on the web project in the Project Explorer.
2. Choose Properties.
3. Go to the "Web Project Settings" page.
4. Change the value of the Context Root field.
Greetings,
Kaloyan
"Rick Baril" <rbaril@forecasttech.com> wrote in message
news:feof80$3cu$1@build.eclipse.org...
> find similar questions left unanswered. I'm running Ubuntu 7.04. Any ideas
> Regards,
> Rick Baril
Previous Topic:There are no projects that can be added or removed from the server.
Next Topic:How to Run Oracle (OC4J) with userthreads switch from WTP?
Current Time: Fri Jul 25 21:19:54 EDT 2025
Powered by FUDForum. Page generated in 0.03389 seconds
