Home » Eclipse Projects » GEF » Move connection label
Move connection label [message #201971] Fri, 04 November 2005 16:46 Go to next message
I am trying to move a Label that is the child of a connection, so a added a
XYLayoutPolicy to my ConnectionEditPart. But when I try to move the Label,
the DragEditPartsTracker always thinks that the DiagramEditPart is the
target and creates an orphan request. And when it has a command for those,
it changes the request to an add request and wants a command from the
DiagramEditPart.
What am I doing wrong? Is there a way to tell the DragEditPartsTracker that
the target is actually the owning connection?
Re: Move connection label [message #201987 is a reply to message #201971] Fri, 04 November 2005 22:33 Go to previous messageGo to next message
> DiagramEditPart.
I been intending to do this for a while now.static labels is kinda weak.
Anyway, is your Label a figure or an editpart? If you want to drag it
around seperately from the connectioneditPart then it will need to be
inside its own editpart. That will be my strategy anyway.
CL
Re: Move connection label [message #202183 is a reply to message #201987] Mon, 07 November 2005 13:10 Go to previous messageGo to next message
Yes, of course I need EditParts for anything that can be touched.
I got it to work by overriding
ConstrainedLayoutEditPolicy.createAddCommand() in my DiagramEditPart's
XYLayoutPolicy and returning an empty command.
But this looks a little like a hack to me, I am wondering if there is a
better way to it.
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:dkh95d$jdv$1@news.eclipse.org...
>> a XYLayoutPolicy to my ConnectionEditPart. But when I try to move the
>> Label, the DragEditPartsTracker always thinks that the DiagramEditPart is
>> the target and creates an orphan request. And when it has a command for
>> those, it changes the request to an add request and wants a command from
>> the DiagramEditPart.
>> that the target is actually the owning connection?
> CL
Re: Move connection label [message #202206 is a reply to message #202183] Mon, 07 November 2005 14:00 Go to previous messageGo to next message
Felix, if I remember, I referred you to look at the code of a plugin which has connection-label movement facility http://qvtp.org/downloads/qvtp-eclipse/. Didn't that help you to solve your problem ?
Venkat
Re: Move connection label [message #202239 is a reply to message #202183] Mon, 07 November 2005 17:03 Go to previous messageGo to next message
Ahh, so you have an editpart that contains your Label, and that
LabelEditPart is the child of the ConnectionEditPart which in turn is a
child of the DiagramEditPart.
Great, thats what I planned to do.
As to your direct situation. Is your DiagramEditPart your drawing so to
speak? and your ConnectionEditPart is ontop of that?
I'm surprised its not working. I Can only imagine your problem is that
your LabelEditPart is not returning a command for the move request. Set
a breakpoint in the LabelEditParts getCommand(Request) method and see
why its not returning an appropriate command. Im my experience, unless
you specifically do something to stop it, the childmost editpart gets
first shot at the command. As long as it is still returning true for
isSelectable() since move first requires selection.
Make sure your LAYOUT_ROLE edit policy is creating a command to move
this child too. I am speaking of the policy in the ConnectionEditPart
since its containing the Label.
CL
> better way to it.
>>CL
Re: Move connection label [message #202260 is a reply to message #202206] Mon, 07 November 2005 17:18 Go to previous message
Thanks, I didn't see that qvtp had moveable labels.
Your solution of overriding DragEditPartsTracker.getTargetEditPart() looks
much simpler.
"venkataramana" <venkataramanam@gmail.com> wrote in message
news:1427389.1131390045319.JavaMail.root@cp1.javalobby.org...
> your problem ?
> Thanks
> Venkat
Previous Topic:Connections start one pixel away from node
Next Topic:Remove model objects or remove visuals?
Current Time: Sat Jun 07 09:07:00 EDT 2025
Powered by FUDForum. Page generated in 0.03826 seconds
