Publishing in WTP 2.0.x vs WTP 1.5.x [message #201887] |
Thu, 11 October 2007 11:17  |
Originally posted by: mauro.molinari.cardinis.com
Hello all!
Does anyone experience a noticeable reduction in publishing performance
in WTP 2.0.x relatively to WTP 1.5.x?
We develop a (big) webapp with WTP and we're using Tomcat 5.5. From when
we switched to WTP 2.0.x (clean install), it seems that Eclipse
publishes the whole webapp EVERY time it has to do publishing... so, it
seems not to do it in an incremental way anymore... The result is that
it always takes minutes to publish...
Republish is often fast, but sometimes my co-workers say that it's very
slow, too, because Eclipse seems to do a full publish operation...
It this normal?
Mauro.
Re: Publishing in WTP 2.0.x vs WTP 1.5.x [message #201966 is a reply to message #201942] |
Fri, 12 October 2007 02:46  |
Larry Isaacs ha scritto:
> There appears to be a bug where the publish information used to derive
> the publish delta for a module doesn't persist successfully in WTP
> 2.0.x. Each time you start a new Eclipse session, the first publish
> won't be able to retrieve the info and do a full publish instead. Since
> this info is cached, I believe the incremental publishing should work
> for the remainder of the session. It this consistent what you are seeing?
> Cheers,
> Larry
> P.S. I created https://bugs.eclipse.org/bugs/show_bug.cgi?id=206087 for
> this bug.
Hi Larry,
yes, when I first start Eclipse, with WTP 2.0.x the publishing is always
done from scratch, as you say.
I'll try to make further investigation whether this problem arises also
during the remainder of a session.
Thank you!
Mauro.
FUDForum. Page generated in 0.24424 seconds
